Associated Reflex 14B/14T >
Like Tree231Likes
Old 08-02-2024 | 01:41 PM
  #901
Mac The Knife's Avatar
Originally Posted by ronnie_space
Just built running chassis so just about to fit. But just realised the kit pinion does not fit the motor shaft.
The HW motor has an 1/8th inch shaft,,,,, I used a Hot Racing 18 tooth pinion gear. They are a 0.5 mod gear.
Mac The Knife is online now
Old 08-02-2024 | 01:53 PM
  #902
ronnie_space's Avatar
Thanks for the recommend - just need to find one - all seem out of stock online.
ronnie_space is offline
Old 08-03-2024 | 03:55 AM
  #903
These from LC Racing will work. They have an 1/8th inch bore. https://casterracingmi.com/index.php...roduct_id=1604
ronnie_space likes this.
Old 08-06-2024 | 02:30 PM
  #904
Thank you! am on it!
Old 08-07-2024 | 01:04 PM
  #905
Wouldn't deliver to UK so I have sourced/ordered this.
M0.5 Module 0.5 0.5M 18T 18 Teeth Tooth Motor Pinion Gear Black 540 3.175mm Bore
Old 08-07-2024 | 01:05 PM
  #906
Do anyone know if I need to run the fan with this or can I leave off? Seems rather high in height ESC plus fan.
Anyone know if can leave fan off on 10BL60 Sensored ESC?
Old 08-12-2024 | 12:55 AM
  #907
I don't know for sure - but would guess that you'll be OK without it.
Check temps after a 5min run maybe?
HotLaps is offline
Old 08-12-2024 | 12:56 AM
  #908
Anyone having issues blowing out shocks? Can we buy replacement shock seal kits for these?
HotLaps is offline
Old 08-12-2024 | 05:41 AM
  #909
On amazon,,,
Amazon Amazon
Old 11-02-2024 | 02:10 AM
  #910
It has a center diff, which is kind of awesome. Given the popularity of the mini 8 and the LC Racing 1/14 rigs, this has a decent shot.
Might come with cvds standard (can’t tell yet) so between those and the center diff it seems very competitive and well-priced.
noithatduyanh is offline
Old 11-25-2024 | 12:24 AM
  #911
keuk's Avatar
rms1776 Did you cut the original shaft cover to make the clamp for engine and diff bearing ?
keuk is offline
Old 11-29-2024 | 10:49 AM
  #912
Yes so that i can make a new one out of aluminum to hold down the motor better also using steel inserts for more strength.
rms1776 is offline
Old 12-03-2024 | 08:38 PM
  #913
Default New motor mount
It is a sliding motor mount that can fit a 16t, 17t & 18t pinion. Reason for making is so that I can get the motor lower to the chassis and the motor is more secure.
BoxxerBoyDrew likes this.
rms1776 is offline
Old 12-04-2024 | 08:44 AM
  #914
AWESOME WORK on the custom chassis!!! U got skills!!!
BoxxerBoyDrew is offline
Old 12-16-2024 | 09:43 AM
  #915
I’d like to see much more of this one…
Littlemotor414 is offline
