Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree6563Likes
USGT
Last edit by:
Print Wikipost
Old 12-24-2023 | 01:55 PM
  #12061
The biggest difference between the USGT times at this race vs FWD were that the "fast" lap time in usgt was 9.60, which is only slightly faster than FWD. But they were maintaining 9.6 to 9.0 for the majority of the run in usgt.
c.edwards is offline
Old 12-24-2023 | 03:44 PM
  #12062
If we don't have enough in each class at our club we will run the FWD and USGT cars together. I run USGT and it's an interesting race. Coming out of the tight corner leading onto the straight I will leave the FWD cars by a few feet as they struggle getting straight line traction. But with less weight they will catch up quickly in the tight sections.
glennhl is offline
Old 12-28-2023 | 06:33 PM
  #12063
Razathorn's Avatar
Default One big one small
Thought this thread would enjoy my matching seven20 gt cars. Usgt is a cero ultra v2.
Razathorn is offline
Old 01-09-2024 | 10:01 PM
  #12064
woofenstein's Avatar
I run in 21.5 TC also and notice quite a bit of difference in how the USGT tires wear and handle.
How do you guys differ your setup for the RIDE/GravityRC tires vs TC tires? Are you running same, more or less camber? Any other setup differences to accommodate for the characteristics of those tires?
I run on high grip asphalt in mostly warm conditions, we typically run 36R TC tires.
Interested to know your setup tips!
woofenstein is offline
Old 01-10-2024 | 08:17 AM
  #12065
On asphalt I would run 2 degrees camber front and rear for TC tires. In USGT I would run 1.5 in the rear and 1 in the front.
glennhl is offline
Old 01-11-2024 | 01:52 PM
  #12066
I typically only run on CRC black carpet, though my USGT and Stock Touring cars are generally setup identically other than camber, and USGT typically is 1.0-deg less than Stock Touring. I've found this provides the best tire wear on USGT without compromising grip.
In my experience, if you want to make a significant change in camber, and if your tires already have a significant amount of runs on them, a camber change of more than 0.5-deg will generally result in sub-optimal performance cause the tires will not be making the correct amount of track surface contact since they have already worn to a different camber setting that caused increased wear on the inside or outside edges of the tire. If that is your case, my suggestion would be to install new tires and try the new camber setting..
kn7671 is offline
Old 01-11-2024 | 04:23 PM
  #12067
Raman's Avatar
What car is this supposed to be?
ARES-1 1/10 GT On-Road Body by Bittydesign
Raman is offline
Old 01-11-2024 | 08:58 PM
  #12068
LonnyJ1950's Avatar
https://www.aresdesign.com/en-us/
New supercar.
LonnyJ1950 is offline
Old 01-11-2024 | 09:31 PM
  #12069
Vertebreaker's Avatar
I guess it is loosely based on the ARES-S1. I don't know if they do actually have a version like this.
Vertebreaker is offline
Old 01-12-2024 | 06:54 AM
  #12070
Dan's Avatar
Dan
Looks a little similar to the Zoo Racing Bwoah body profile.
Dan is offline
Old 01-12-2024 | 08:21 AM
  #12071
Raman's Avatar
Hadn't heard of this Ares before. Since they’re a small company, seems Bitty can get away with calling it Ares.
initially thought it was the Maserati MC20 but it’s too longer.
Raman is offline
Old 01-14-2024 | 12:18 PM
  #12072
NutDriver's Avatar
Has anyone raced the Exotek GT-F body yet? How does it compare to the P1z, Bwoah, etc?
NutDriver is offline
Old 01-17-2024 | 02:31 PM
  #12073
robk's Avatar
The back of the car is squared off compared to the real car. Maybe it's for molding purposes?
I think they were going for this version-
NutDriver likes this.
robk is offline
Old 01-17-2024 | 11:02 PM
  #12074
gigaplex's Avatar
Shock towers/bulkheads/body posts are probably too low on even the current generation cars to fit a body that was scale accurate to that.
gigaplex is offline
Old 01-18-2024 | 09:53 AM
  #12075
Just get a car that doesn't have shock towers: A800 or IRIS. The P1Z comes with two cut lines, one for shock tower cars and a higher cut line for the A800/IRIS.
glennhl is offline
