question about programming bldc controls
Bought a kpl engine control from Temu.2205 A2205 7.6 A 1400 KV. How should it be programmed (calibrated) to make the control lever work from min to max position. Best regards Goran
No manual with the product?
Contact the seller?
Most of these things have no calibration and should work if you put all trims at 0 and all endpoints at 100% or else every time when swiching on in neutral you have to give full throttle and full brake
Contact the seller?
