-   -   question about programming bldc controls (https://www.rctech.net/forum/radio-electronics/1119807-question-about-programming-bldc-controls.html)
Goran Axelsson 01-08-2024 10:20 PM
Bought a kpl engine control from Temu.2205 A2205 7.6 A 1400 KV. How should it be programmed (calibrated) to make the control lever work from min to max position. Best regards Goran
Roelof 01-08-2024 11:27 PM
No manual with the product?
Contact the seller?
Most of these things have no calibration and should work if you put all trims at 0 and all endpoints at 100% or else every time when swiching on in neutral you have to give full throttle and full brake
