Go Back  R/C Tech Forums > General Forums > Oval, Larger Scales and More
New 1/8th 4WD basic class ???!!! >
Like Tree27Likes
Old 03-18-2022 | 10:32 AM
  #286
1/8 IC Fan's Avatar
Originally Posted by Sir 51D3WAYS
^Interesting. Thanks for the info. Can these handle bumpy tracks? (or atleast bumpy as can be for normal 1/8 full suspension GP cars) Can it keep up with the normal cars performance/run time wise? I'm toying with the idea of getting one as a cheaper alternative to the full fledged affair. Rear spool and front one way I assume?
S1d3ways, I have run mine on bumpy european tracks - Augsburg, Bamberg and in Italy (forgot which we were at) . They can be quite forgiving. Anywhere I have run 2wd Pan, these do better. I have slotted the rear body post holes slightly so the body will allow the chassis to flex without binding on the body. Where the Buri Spec tires are not enforced I usually run a shore or two lighter in front and rear tires, as the car will grip just fine but the softer shore also helps "suspend" the chassis.
I still.run a 1st gen car and am sure the newer ones will get you close to the full suspension cars.
Can not go wrong with a "Big" Pro10, lol.
Sir 51D3WAYS likes this.
1/8 IC Fan is offline
Old 09-08-2023 | 08:45 PM
  #287
1/8 IC Fan's Avatar
Old 09-11-2023 | 12:36 PM
  #288
petersen114's Avatar
Originally Posted by TomAT
Hi to all,
I just launched the latest versions of my 2 cars with a lot of improvements:
- the side belt type BURI-Racer E1.4 and
- the midle belt type BURI-Racer E2.2
just look at attached file for more detailed information - the new website will be unlocked in the next days
BURI-Racer E1.4 roller chassis
full equipped BURI-Racer E1.4
BURI-Racer E2.2 roller chassis
Pretty wild looking car.
petersen114 is offline
Old 09-22-2024 | 10:34 PM
  #289
I bought a Xray X8 and I wanna run it on CRC carpet. Do you know what tires are good for carpet? Thanks in advance
Fagu is offline
Old 03-01-2025 | 09:12 PM
  #290
Zerodefect's Avatar
Which track has 1/8th on carpet?
1/8 IC Fan likes this.
Zerodefect is offline
Old 03-03-2026 | 02:42 AM
  #291
just a basic and cheap 4wd class even rubber tires and a motor restriction to help keep costs down yes that would be awesome
okracer is offline
