Like Tree495Likes
JConcepts Thread
Old 03-23-2023 | 06:04 AM
  #10441
When will the pre-mount Pin-swag 2wd front's be available in the UK? Part No. 3181-201011.
https://jconcepts.net/pin-swag-2wd-front-pre-mounted
I really want to try these as an alternative for the usual Schumacher LP cut stagger but they don't seem to be available anywhere?
Thanks.
jph98 is offline
Old 03-23-2023 | 06:51 AM
  #10442
PW's Avatar
PW
Thanks.
With it being a fairly new release, I don't think Schumacher or Ruddog has received any yet. You could order them direct or wait for the UK dist to receive them.
jph98 likes this.
PW is offline
Old 03-27-2023 | 01:36 PM
  #10443
Wondering when A3 reflex and detox will be in stock?
cmotzner is offline
Old 03-28-2023 | 08:32 AM
  #10444
PW's Avatar
PW
I'm hearing mid/late April for Reflexes (A3). Haven't seen anything regarding the Detox.
PW is offline
Old 03-28-2023 | 11:52 AM
  #10445
Cain's Avatar
Cool to see a step-pin style tire back out there, do you think you all would make a dirt style compound version of these like Green or blue?
For the new pin swag 4wd fronts, are you finding you still need to glue the sidewalls like we do with the fuzzbite 4wd fronts? For rear tires do you all like to still combine them with fuzzbite rears or pin swag rears?
Cain is offline
Old 03-28-2023 | 12:59 PM
  #10446
PW's Avatar
PW
No plans at the moment.
They still glue the sidewalls, but more inline with the 2wd. Still using Fuzz Bite rears 100% of the time on black carpet.
PW is offline
Old 03-28-2023 | 01:20 PM
  #10447
Cain's Avatar
Gotcha, nice thing at least tires are not directional then if I am seeing it right.
Cain is offline
Old 03-29-2023 | 11:47 AM
  #10448
Any word as to when the 1/8 Recon tires will be available?
Cain likes this.
BJT2814 is offline
Old 04-02-2023 | 06:11 PM
  #10449
They (pin swag 4w fronts) are amazing. Somehow they give more steering but simultaneously make the car easier to drive. Way less twitchy.
Cain likes this.
MrLean is offline
Old 04-03-2023 | 04:35 PM
  #10450
Hate to post another "when will this item be available" question but........ I've had 1/10 rear buggy double dee's & sprinters on back order since December. Can you give me some hope?
Cain likes this.
Ram12375 is offline
Old 04-04-2023 | 12:06 PM
  #10451
PW's Avatar
PW
Production samples have been given the green light, so it's has to be very close.
Unfortunately it's not the tires holding us up, it's the inserts. So inserts are in transit and once they arrive, they will begin shipping again very shortly .
PW is offline
Old 04-27-2023 | 08:33 AM
  #10452
Cain's Avatar
Is it possible to buy your carpet foam inserts for different tire types separate? For example, the stadium truck carpet foams?
As part of that, how do the stadium truck carpet foams compare to your foams you include with your dirt style tires like the stadium truck goosebump? Looking at foams here since the track is bumpy for your molded inserts that are pretty stiff for these conditions, but don't see the foams to be bought anywhere and comparing how the carpet and "dirt" style foams feel by hand.
Cain is offline
Old 04-27-2023 | 08:52 AM
  #10453
PW's Avatar
PW
Unfortunately no
It's been a long time since I've handled/used the white foam that comes with the Goosebumps, but I would probably say it's just slightly firmer/more dense than the grey carpet foam.
Cain likes this.
PW is offline
Old 05-07-2023 | 12:46 PM
  #10454
Which body will fit better for B3.1e
Asso B4e - 0477 or Mugen mbx-8 eco - 0338 ?
hardijs is offline
Old 05-08-2023 | 06:16 AM
  #10455
Could you explain the mounting directions on the new Recon tire?
cooper126 is offline
