Hobbywing 4268 sensor issue. >
Old 11-12-2022 | 11:41 AM
Default Hobbywing 4268 sensor issue.
My motor now goes forward when I go in reverse :-)
The car goes forward fine and smooth, but when I go in reverse, it splutters and goes forward.
Unplugged the sensor cable and all is good.
Also tested ESC with another motor, with sensor.
​All is good.
Suspect the hall sensor is knackered. Any ideas on how to fix or replace the hall sensor board.
Skynet5 is offline
Old 11-12-2022 | 01:22 PM
The 4268 motor is a 4 pole? The ESC can handle a 4 pole motor?
Roelof is offline
Old 11-12-2022 | 01:30 PM
Yes and yes. All worked for many many practises and race days. Just started happening. It was a hobbywing combo with an xr8
Setup not the issue.
I just want advice on replacing hall sensor or if there is something else that can be done.
Skynet5 is offline
Old 11-12-2022 | 05:32 PM
there is no hall sensor modules 42size
only 540 size Hobbywing hall sensors are awaible
have you another sensor cable to try ?
you need new motor ,
you can sell this unsensored cheap like 40-50$ , or keep it unsensored to something fun
what KV is it ?
flymetonight is offline
Old 11-13-2022 | 01:21 AM
If the motor can be opened then you can always check the sensor PCB is some soldering has become lose or the PCB has a damaged trace.
But yes, I also would try another sensor cable first, they are most of the time the cause of issues.
Roelof is offline
Old 11-13-2022 | 04:38 AM
what KV is it ?
Thanks mate. I've emailed HW and the UK distributor on the off chance.
I've soldered it back up on to my spare ESC and will just keep it as is.
I guess I could have just swopped the end covers around in the end lol.
It's a 1900kv motor.
Skynet5 is offline
