USGT
Just to check, are you using tire sauce?
Also, when I first started running usgt, I was told it helps to sand down the middle ridge off the tire. My routine is to clean the tires after coming off the track with break cleaner, then 5 mins before getting on the track, sauce the tires. Then when you set the car down, hold the car and hit the throttle a few times and run.
The tire puffing is why the droop gauge number is innacurate, and we use droop over ride height in VTA and USGT. the TC tires are belted so thier size stays pretty much, but the VTAs and USGT tires are not belted currently. If i have new tires at 65mm and u have old ones at 69mm, to get the same amount of droop over ride height, we will have 2 totally different gauge numbers. my rule of thumb is if your over 68mm ur close to needing new tires.
if u ever wonder why folks can get away with no glue its from having fresher tires.
ultimately, you can fight the aged tires, and make setup changes to compensate, but at the end of the day its a bandaid for the inevitable.
Just so I understand completely.....clean the tires with brake cleaner after every run. Then sauce them 5 min before the race and do a burnout on the carpet to get the excess sauce off them.
Am I leaving anything out? I've only used sauce on VTA tires. Never used brake cleaner on them. it took a race day or two before new vta tires would wear in.
Also, when I do sauce the front tires in USGT, am I only saucing the inner half of the tread or doing the entire tread across?
Everyone uses SXT 3.0 at the track. I just started using brake cleaner.
on usgt, I usually do about a quarter of an inch on the inside. On vta, I do the inside first two tread.
I’ve have yet to see a carpet track that didn’t allow sauce. If you know of one ( or more) that don’t, could you please let us know? And what is there reasoning?
If you are intending to say they don’t allow paragon or anything like it, or costic cleaners that will stink up and give off toxic fumes indoors then yes I agree. I do know carpet tracks that limit tire sauce to SXT 3.0 or similar.
So you raced in a non-permanent facility and used the normal office-type carpet that was on the floor there already? Well, in that case I can understand banning sauce, but that seems to be a rather special case, not the norm.
Isn't that gonna mess up the carpet if everyone does it?
Yeah, which is it.
Yeah, which is it.
6563Likes
