Schumacher Eclipse 4 >
Like Tree138Likes
Old 01-25-2022 | 06:09 AM
  #136
choisan's Avatar
is it going to have a E5 soon?
choisan is offline
Old 01-26-2022 | 12:01 AM
  #137
TrevCoult's Avatar
Not in the near future, no. The company feel that people have not had the chance to make the most of the E4 yet due to the lack of racing.
TrevCoult is offline
Old 01-26-2022 | 04:36 PM
  #138
choisan's Avatar
or any running change to include the new revised damper piece in the current kit?
choisan is offline
Old 01-26-2022 | 11:23 PM
  #139
TrevCoult's Avatar
That one I can't answer I'm afraid. Sam was running the new damper rods at the BRCA National last weekend though and they are definitely easier to fill. No difference in feel either.
Rick Vessell likes this.
Old 01-27-2022 | 12:26 AM
  #140
choisan's Avatar
if that is a significant advantage/improvement, it would be nice to include, right? my 2 cents
choisan is offline
Old 01-29-2022 | 07:05 PM
  #141
Hi Juniorabca, I try to put the A12 gear diff onto e4 but notice the spur gear is tocuhing the chasis. I have a pictures but don't have permission to post it here. Do you have the same issue and how did you fix it? Thanks.
henry_y_leung is offline
Old 01-29-2022 | 08:27 PM
  #142
i used a thin spur with the oring on mine and it cleared fine it was a 68t from genesis
2dialed is offline
Old 01-30-2022 | 03:35 AM
  #143
Thanks a lot
Old 01-30-2022 | 01:47 PM
  #144
Like 2dialed said you will have to use a thin spur with the oring. I used the RW (https://www.rwracing.co.uk/product/acetal-diff-spurs) ones and just found the smaller Axon (https://www.amainhobbies.com/axon-dt...08189?v=694287) ones work too. This way you don't have to do anything to the chassis. I also added one thin axle spacer to clear it just that much more but was not needed in the end.
Jon
Juniorabca is offline
Old 01-31-2022 | 06:02 AM
  #145
Thanks Jon
Old 03-14-2022 | 12:57 PM
  #146
Robert K's Avatar
A Couple of laps arround the awesome RC Indoor Bleiswijk track located in the Netherlands.
Running the Schumacher Eclipse 4, Montech M21, Contact T35, 13.5T Blinky.
Hyperlink seems broken:
www.youtube.com/watch?v=DDc-30D9viM
Robert K is offline
Old 03-15-2022 | 06:02 PM
  #147
EDWARD2003's Avatar
Could someone measure the dimensions of the thrust bearing that comes with the Eclipse. Looking for the outer, inner and thickness.
Thank you in advance.
EDWARD2003 is offline
Old 03-15-2022 | 06:16 PM
  #148
Hugh Jazz's Avatar
3.06 inner hole 7.8mm o/a diameter. Each plate is 1.1,, thick for a o/a thickness of 3.45mm
Hugh Jazz is offline
Old 03-15-2022 | 09:09 PM
  #149
I don't have one at hand to measure but either side of the thrust washer is slightly different. Inner diameter on large side as mentioned in last comment, small side I think is 2.9mm.
mike33 is offline
Old 03-16-2022 | 02:12 AM
  #150
Hugh Jazz's Avatar
Mike is correct. I missed that. so the above is the small plate and the bigger plate is 3.2 inner hole on a 8mm diameter
