Schumacher Eclipse 4
#137
#139
#141
Hi Juniorabca, I try to put the A12 gear diff onto e4 but notice the spur gear is tocuhing the chasis. I have a pictures but don't have permission to post it here. Do you have the same issue and how did you fix it? Thanks.
#142
i used a thin spur with the oring on mine and it cleared fine it was a 68t from genesis
#143
Jon
#145
Thanks Jon
#146
A Couple of laps arround the awesome RC Indoor Bleiswijk track located in the Netherlands.
Running the Schumacher Eclipse 4, Montech M21, Contact T35, 13.5T Blinky.
Hyperlink seems broken:
www.youtube.com/watch?v=DDc-30D9viM
#149
I don't have one at hand to measure but either side of the thrust washer is slightly different. Inner diameter on large side as mentioned in last comment, small side I think is 2.9mm.
