Schumacher Eclipse 4 >
Like Tree138Likes
Old 03-17-2022 | 05:57 AM
  #151
EDWARD2003's Avatar
Cheers for the dimensions.
EDWARD2003 is offline
Old 04-05-2022 | 06:39 AM
  #152
clinttredway's Avatar
I'm having an issue where my servo gets locked after a small hit while turning through a corner. Anyone else have this issue?
clinttredway is offline
Old 04-05-2022 | 07:22 AM
  #153
Car Breaker's Avatar
rarely but I do. they don't have any limiter there. if you allow too much steering throw this will happen occasionally.
can you show me how your front end is?
clinttredway likes this.
Car Breaker is offline
Old 04-05-2022 | 07:26 AM
  #154
I'm thinking of adding limiters. but I will play with the steering too as well to see if I can eliminate it
Car Breaker likes this.
Old 04-05-2022 | 11:26 AM
  #155
I did. I drilled holes on the lower front beam (U8140) and bought extra chassis posts (U7938) as limiters.
I'm confused why the issue doesn't happen with my E3.
Red141 is offline
Old 04-05-2022 | 11:48 AM
  #156
I agree. My friend that runs a E3 doesn’t have this issue either.
Old 06-15-2022 | 04:12 AM
  #157
Krazed Builds has released new high quality Carbon Fiber front base plates that shorten the wheelbase from 200mm to 195mm for med/high grip carpet and a new 1/2 degree camber strap. Nice tuning pieces that aren't available elsewhere.
https://www.krazedbuilds.com/wdpress/?s=eclipse4
Robbob and Juniorabca like this.
Butler#11 is offline
Old 07-16-2022 | 06:02 PM
  #158
BadSign's Avatar
What's a good source for Al/Ti screws in the US? I can't find a source for both.
BadSign is offline
Old 07-16-2022 | 06:22 PM
  #159
Originally Posted by BadSign;[url=tel:15921400
15921400[/url]]What's a good source for Al/Ti screws in the US? I can't find a source for both.
klinik rc usually has ti screws
Juniorabca likes this.
Old 07-24-2022 | 05:54 PM
  #160
BadSign's Avatar
I switched over to the cf chassis to race 17.5 and GT12 at my local club. The car became more responsive on throttle and carried quite a bit more speed in the corners. I was able to set the fastest laps of our current layout as well. Overall a very positive change.
BadSign is offline
Old 07-29-2022 | 04:58 PM
  #161
ChadoSan's Avatar
Has anyone tried to fit the Atom 2 gear diff to their Eclipse?
ChadoSan is offline
Old 07-30-2022 | 01:57 AM
  #162
TrevCoult's Avatar
It won't fit, makes the car too wide.
TrevCoult is offline
Old 08-14-2022 | 05:24 PM
  #163
I just switched mine to the CF chassis.. hoping to get it out on the track this week see how it differs from the aluminum.
I'm the only schumacher at my track, does anyone have a base setup for high bite carpet?
Old 08-17-2022 | 08:02 AM
  #164
ChadoSan's Avatar
ChadoSan is offline
Old 08-17-2022 | 05:40 PM
  #165
Getting this ready to get back on the track
