Engine Break in-How many tanks vs. oil bath >
Like Tree5Likes
Old 12-08-2021 | 08:27 AM
  #16
Originally Posted by silence360
Castor oil, as in vegetable oil? Also your pinch meter, is that the amps of the motor that you are monitoring that I think I read you stated would reduce as pinch is reduced.
With most kart/bike shops you can find race grade cator oils, I have a liter of Euro Racing-1 at hand when needed as extra oil in the fuel. Other people just buy plain castor at the drug store.
Yes, the meter is a simple 2 dollar ammeter measuring the amps of the electric motor. Because of the pinch the readout is not stable but still it is a good indicator, at the end when the pinch is lower the readout becomes lower and more stable.
Roelof is online now
Old 12-08-2021 | 09:33 AM
  #17
The motor selection 12v 840rpm should be good, I assume this is the max rpm. For PWM controller can it be a simple one or one with a digital display?
silence360 is offline
Old 12-08-2021 | 10:01 AM
  #18
Due the lower gear ratio with a twice as much rpm motor you also get half the torque, if you then lower the rpm to 400 by a voltage change then you also get half the torque, so you will have a quarter of the torque than an 400rpm motor. In my link there was a 420 rpm motor.
Old 12-08-2021 | 11:10 PM
  #19
Thanks for sharing the information.
fridayrack is offline
Old 12-14-2021 | 10:51 PM
  #20
How ever many tanks you out of 1 gallon nitro.
kahuna2793 is offline
Old 12-15-2021 | 03:27 AM
  #21
Do the math
dontfeelcold likes this.
Old 12-15-2021 | 12:30 PM
  #22
fyrstormer's Avatar
(duplicate post)
fyrstormer is offline
Old 12-15-2021 | 12:31 PM
  #23
fyrstormer's Avatar
(duplicate post)
Old 12-15-2021 | 12:32 PM
  #24
fyrstormer's Avatar
(duplicate post)
Old 12-15-2021 | 12:40 PM
  #25
fyrstormer's Avatar
Castor oil isn't vegetable oil. It does come from a plant, but it's not digestible. This is important because the properties that make it not digestible also make it a much better engine lubricant than vegetable oil. Using vegetable oil from the grocery store won't work, partly because its smoke point is too low for use inside a combustion engine, and partly because it doesn't dissolve in alcohol, which is necessary for proper oil delivery in an alcohol-powered engine.
Castor oil from the pharmacy (sold as a laxative, again because it's not digestible) works fine, though. I've been adding a small amount (about a shot-glass-full per gallon) to my nitro to raise its oil from 11% to 12% for years.
Old 12-16-2021 | 04:50 AM
  #26
This is what is available in my country.
Old 12-16-2021 | 05:36 AM
  #27
Just go to a kart shop or a dirtbike shop and get some race grade castor oil.
Rick Vessell likes this.
Old 12-16-2021 | 06:08 AM
  #28
Old 12-16-2021 | 06:17 AM
  #29
Yep
https://www.u-univerzal.com/product/race-castor-oil/
Old 12-16-2021 | 07:36 AM
  #30
Cool, cause that is all that I've got access to here.
