Go Back  R/C Tech Forums > General Forums > Rookie Zone
Newbie diagnostic help please? >
Old 12-02-2021 | 08:15 PM
Questions?? Newbie diagnostic help please?
Hi!
I have a 1/12 G wagen that's having problems, hoping someone on here can help.
When I turn it on it will run for a couple seconds forward or back and then stop.
It sometimes steers for a couple seconds and then stops.
My son has the same truck so I used his ESC, same thing.
I used his remote, same thing.
What else should I try?
Thank you!
AC
adjacorc3000 is offline
Old 12-02-2021 | 11:53 PM
the rc guy's Avatar
make n model might help.
have you checked the battery?
the rc guy is offline
Old 12-03-2021 | 06:48 AM
What does "make n model" mean?
I've checked the battery and tried my son's battery, same thing happens.
Old 12-03-2021 | 07:46 AM
the rc guy's Avatar
who made it ,?
actual model # name of rc on box.
Old 12-03-2021 | 02:52 PM
MN86S RTR. Same company that makes the MN90/MN99, I think they’re called MN Models.
Old 12-06-2021 | 11:44 AM
I know it’s not the best RC out there but just a starter RC for me and my 4 year old.
Old 12-06-2021 | 01:49 PM
OffRoadJunkie's Avatar
Originally Posted by adjacorc3000
Hi!
Thank you!
AC
So, you swapped the receivers around from your sons car and there was no change?
OffRoadJunkie is offline
Old 12-06-2021 | 02:25 PM
yes correct
Old 12-07-2021 | 12:23 PM
it might be your motor. If it is shorting out, it will throw your ESC into safe mode and shut down. Did you try swapping out the motors?
Old 12-07-2021 | 12:25 PM
I haven’t done that yet, sounds like that’s my next step? There’s some kind of circuitboard on the front of the motor, could it be something to do with that too?
Old 12-07-2021 | 05:56 PM
Is your motor a brushless motor?
Old 12-07-2021 | 06:23 PM
no it’s a brushed motor.
Old 12-08-2021 | 01:33 PM
the rc guy's Avatar
I thought you had switched all electronics if motor is same then id check,, anything that is still same in rc could be it
Old 12-08-2021 | 02:46 PM
I don't know what that circuit board on the motor is if it's not the ESC. I would have to see a picture of it.
