Newbie diagnostic help please?
Hi!
I have a 1/12 G wagen that's having problems, hoping someone on here can help. When I turn it on it will run for a couple seconds forward or back and then stop. It sometimes steers for a couple seconds and then stops. My son has the same truck so I used his ESC, same thing. I used his remote, same thing. What else should I try? Thank you! AC |
make n model might help.
have you checked the battery? |
What does "make n model" mean?
I've checked the battery and tried my son's battery, same thing happens. |
who made it ,?
actual model # name of rc on box. |
MN86S RTR. Same company that makes the MN90/MN99, I think they’re called MN Models.
I know it’s not the best RC out there but just a starter RC for me and my 4 year old.
Originally Posted by adjacorc3000
(Post 15850273)
Hi!
I have a 1/12 G wagen that's having problems, hoping someone on here can help. When I turn it on it will run for a couple seconds forward or back and then stop. It sometimes steers for a couple seconds and then stops. My son has the same truck so I used his ESC, same thing. I used his remote, same thing. What else should I try? Thank you! AC So, you swapped the receivers around from your sons car and there was no change? |
Originally Posted by OffRoadJunkie
(Post 15851439)
it might be your motor. If it is shorting out, it will throw your ESC into safe mode and shut down. Did you try swapping out the motors?
(Post 15851796)
Is your motor a brushless motor?
(Post 15851897)
I thought you had switched all electronics if motor is same then id check,, anything that is still same in rc could be it
I don't know what that circuit board on the motor is if it's not the ESC. I would have to see a picture of it.
| All times are GMT -7. It is currently 07:17 AM. |
