1s battery maintenance >
Like Tree1Likes
  • 1 Post By mrreet2001
Old 11-03-2021 | 12:05 PM
Default 1s battery maintenance
I’ve been getting deeper and deeper into the 1s 12th racing, got a couple questions on batteries/maintenance.. I recently bought an icharger x6 due to traveling and small size.. I’m looking to find a turbo 35 but that’s like a unicorn.. anyways I’ve been told to discharge them to boost performance.. I’ve never abused my batteries charging them(7700mah-7.7 amps etc) and always put them in storage until the following week..
my question is I’ve seen a discharger that will wire into the x6 but it looks like a pain at times to use. Is there a better setup then buying the discharger for the x6. Should I get a stand alone unit that I can use with all my batteries not just 1s Any help is appreciated
rcracersb is offline
Old 11-03-2021 | 01:01 PM
There is a huge X6 topic where several solutions are provided. The discharger for the X6 is actially no real discharger but it acts like an external load for higher discharge rates.
Of course you can get the SkyRC/GTracing stand alone discharger, not sure if it can handle 1S, you have to look into that.
Roelof is offline
Old 11-03-2021 | 02:37 PM
Bsthetech's Avatar
To do it properly you need an external resistor bank and be able to charge at 40 amps. The X6 maxes out at 30 amps. You'll need a 406Duo or similar.
Bsthetech is offline
Old 11-03-2021 | 03:25 PM
https://www.rcdischarger.com/regener...ger-x6-x8-x12/
biz77 is offline
Old 11-04-2021 | 07:47 AM
mrreet2001's Avatar
Originally Posted by Bsthetech
To do it properly you need an external resistor bank and be able to discharge at 40 amps. The X6 maxes out at 30 amps. You'll need a 406Duo or similar.
Bsthetech likes this.
mrreet2001 is offline
Old 11-04-2021 | 07:59 AM
Unfortunately the SkyRC discharger does not do 1S.
Poor_Boy is offline
Old 11-04-2021 | 08:17 AM
I have a Turbo 35 that is collecting dust. It has been upgraded to LIPO charge. If you are interested, drop me a PM, I'm sure we can work something out.
Martin
rhodopsine is offline
Old 11-06-2021 | 08:44 AM
GerryH's Avatar
Most of the X series discharge banks need to be disconnected to charge, because it's a big resistor inline with the battery. The easiest thing would be to get a iCharger Duo, which is what 99% of racers are using for this function. But I realize it's $350+ investment with a discharge bank.
But since you already have an X6 and power supply, I'd just buy the X6 discharge bank. It's not going to be any more of a pain to use than a Turbo 35. And it's much smaller.
GerryH is offline
Old 11-08-2021 | 12:32 PM
RacinJ's Avatar
If you connect an X6 to a battery power source and set it up in Power Regenerative Mode, you can get the full 30A discharge out of it. It was discussed in the X6 thread and it's in the users manual.
Running the charger from a power supply will not allow this functionality.
RacinJ is offline
