Roche Rapide P12 Evo 1/12th Competition Kit >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree91Likes
Last edit by:
Print Wikipost
Old 08-21-2021 | 10:35 AM
  #226
trx-1racer's Avatar
Originally Posted by RCTVLIVE
HI, I am sorry about that,
1s 21.5 motor
Start around 90mm rollout. So gearing really depends on tire diameter.
I don't plan to run micro tires, so cut to about 43mm I'll be at 48/72 and tune by temp from there.
Longer track? Go up a tooth or 2.... Just remember, lots of factors in gearing, motor, timing, tires, track length, track surface, etc.
trx-1racer is offline
Old 08-21-2021 | 02:31 PM
  #227
Great info, thank you!
RCTVLIVE is offline
Old 09-03-2021 | 03:13 PM
  #228
trx-1racer's Avatar
Same post as the GT12 thread... Need to trim body posts and get a setup that gets around the track. Hopefully it's close enough to begin with. I went mild with long wheelbase and wide front track so I can dial that back as needed...
ptrhahn likes this.
Old 09-13-2021 | 11:04 AM
  #229
Evo 2 announced today
BKUK is offline
Old 09-13-2021 | 11:13 AM
  #230
RocheRCUSA's Avatar
new car announcement - new thread!
Roche Rapide P12 Evo2 1/12th Competition Kit
RacinJ likes this.
RocheRCUSA is offline
Old 09-14-2021 | 10:53 AM
  #231
For anyone looking for a great deal on an EVO1, Roche USA is selling the leftover kits for $210.00. It sounds like the new model will likely experience a price increase given the raw material shortages and shipping issues/price increases.
gwc likes this.
biz77 is offline
Old 10-05-2021 | 03:06 PM
  #232
gwc
Just bought the P12 EVO from Roche USA for $210.00 & $10.00 shipping....WOOHOO😄
trx-1racer and JC3 like this.
gwc is offline
Old 10-19-2021 | 03:52 PM
  #233
JC3's Avatar
JC3
Originally Posted by hanulec
Also the shorter axles are really our popular item--
Front Axle (Spring Steel) -0.5mm
Do these solve a particular problem or offer some advantage?
JC3 is offline
Old 10-19-2021 | 05:20 PM
  #234
hanulec's Avatar
requires less shims to prevent the traditional wheels from wobbling on the axle
gwc likes this.
hanulec is offline
Old 10-19-2021 | 06:17 PM
  #235
JC3's Avatar
JC3
Okay, thanks. I like having the extra room that the kit axles offer.
gwc likes this.
JC3 is offline
Old 10-21-2021 | 07:18 PM
  #236
JC3's Avatar
JC3
I can confirm that the Xpert CI-2401-HV servo fits the floating servo mount. It's almost perfect. I spaced the servo out 3mm from the mount to better line up the link.
This servo is fast and strong. It's a bit noisy right now but hopefully it will quiet down over time. Not liking the plastic horn but very few options exist. I did find two aluminum horns that I ordered to try - NSDRC makes a 20mm and Reefs makes a 26mm which will probably be the one to use.
It would be great if Roche made a mount with 2.5mm holes because the servos mounting tab holes are 2.5mm. I opened them up a bit and the 3mm's fit fine.
CI-2401-HV
Power Supply 6.0V~8.4V
Speed (sec/ 60°) @6.0V: .085sec/60° @7.4V: .069 sec/60° @8.4V: .061 sec/60°
Torque (oz/in) @6.0V: 83.56 oz-in @7.4V: 83.56 oz-in @8.4V: 114.79 oz-in
Dimensions 23.15x29x13 mm
Weight 21g
$92
JC3 is offline
Old 11-19-2021 | 10:41 AM
  #237
Can someone please let me know all the parts needed to convert my EVO 1 to the sliding servo mount?
biz77 is offline
Old 11-19-2021 | 12:40 PM
  #238
gwc
This is the chassis conversion kit but it has the part numbers for the "floating servo mount" if this is what you are looking for.
Roche - Rapide P12 EVO Floating Servo Long Chassis Conversion Kit (210238) (rocherc.com)
gwc is offline
Old 11-19-2021 | 12:54 PM
  #239
hanulec's Avatar
the long chassis has all of the components -- but causes a bunch of other changes.
you need 3 main parts-
1. servo mount - Rapide Aluminium Servo Mount
2. carbon floating mount - Rapide P12 EVO Graphite Floating Servo Plate
3. standoff - 16mm Aluminum Servo Post
this old 2016 kit bundle will give you similar complete set of option parts at a discount as compared to the long chassis - Rapide P12 Floating Servo Chassis Conversion Kit
hanulec is offline
Old 11-19-2021 | 09:21 PM
  #240
Can anyone give me the lowdown on the lightweight axle and hubs: 410042 & 410043? When and why would these be preferred over the standard spool axle? I currently have a diff and am looking to try out a spool. I have the option of purchasing either, standard or lightweight.
Standard solid axle and hub
bentouttashape is offline
