Roche Rapide P12 Evo 1/12th Competition Kit
#226
Start around 90mm rollout. So gearing really depends on tire diameter.
I don't plan to run micro tires, so cut to about 43mm I'll be at 48/72 and tune by temp from there.
Longer track? Go up a tooth or 2.... Just remember, lots of factors in gearing, motor, timing, tires, track length, track surface, etc.
#227
Great info, thank you!
#228
Same post as the GT12 thread... Need to trim body posts and get a setup that gets around the track. Hopefully it's close enough to begin with. I went mild with long wheelbase and wide front track so I can dial that back as needed...
#229
Evo 2 announced today
#230
#232
Just bought the P12 EVO from Roche USA for $210.00 & $10.00 shipping....WOOHOO😄
#233
#235
#236
I can confirm that the Xpert CI-2401-HV servo fits the floating servo mount. It's almost perfect. I spaced the servo out 3mm from the mount to better line up the link.
This servo is fast and strong. It's a bit noisy right now but hopefully it will quiet down over time. Not liking the plastic horn but very few options exist. I did find two aluminum horns that I ordered to try - NSDRC makes a 20mm and Reefs makes a 26mm which will probably be the one to use.
It would be great if Roche made a mount with 2.5mm holes because the servos mounting tab holes are 2.5mm. I opened them up a bit and the 3mm's fit fine.
CI-2401-HV
Power Supply 6.0V~8.4V
Speed (sec/ 60°) @6.0V: .085sec/60° @7.4V: .069 sec/60° @8.4V: .061 sec/60°
Torque (oz/in) @6.0V: 83.56 oz-in @7.4V: 83.56 oz-in @8.4V: 114.79 oz-in
Dimensions 23.15x29x13 mm
Weight 21g
$92
CI-2401-HV
Weight 21g
$92
#238
Roche - Rapide P12 EVO Floating Servo Long Chassis Conversion Kit (210238) (rocherc.com)
#239
R/C Tech Elite Member
This is the chassis conversion kit but it has the part numbers for the "floating servo mount" if this is what you are looking for.
you need 3 main parts-
1. servo mount - Rapide Aluminium Servo Mount
2. carbon floating mount - Rapide P12 EVO Graphite Floating Servo Plate
3. standoff - 16mm Aluminum Servo Post
this old 2016 kit bundle will give you similar complete set of option parts at a discount as compared to the long chassis - Rapide P12 Floating Servo Chassis Conversion Kit
#240
Can anyone give me the lowdown on the lightweight axle and hubs: 410042 & 410043? When and why would these be preferred over the standard spool axle? I currently have a diff and am looking to try out a spool. I have the option of purchasing either, standard or lightweight.
Standard solid axle and hub
