Roche Rapide P12 Evo 1/12th Competition Kit >
Like Tree91Likes
    Hide Wikipost
Old 01-03-2019, 05:19 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Roche Rapide P12 Evo 1/12th Competition Kit
Last edit by: hanulec
Questions/Answers:
Q1. Will the P12 Evo support a traditional style steering servo setup?
A1. Yes. The chassis supports this, but parts are not included.
Q2. Will the P12 Evo support prior Roche P12 front ends featuring a Xenon lower arm?
A2. Yes. Prior front ends will directly bolt on to the new P12 Evo chassis
Q3. What is the maximum size servo width that can be used on the P12 Evo?
A3. Maximum servo width is 33mm
Q4. Which servos fit into the P12 Evo?
A4. (not a complete answer -- working on building up a list)
  • Sanwa SGR-HR (must cut off the top/bottom additional case pieces)
  • Sanwa SRG-HS (must cut off the top/bottom additional case pieces)
  • KO Propo RSx3-12 Digital Mini Servo
  • Futaba High Voltage BLS671SV S.Bus2 HV SX Mini Servo
  • Hitec HS-7235MH Hi-Voltage "Hi-Speed" Metal Gear Digital Mini Servo
  • XPert MI-3301
Print Wikipost
Old 12-07-2020, 07:47 PM
  #196
ospower's Avatar
Default help!
what option parts i need to buy for the us spec to make it more race ready?
ospower is offline
Old 12-08-2020, 03:43 AM
  #197
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Depends upon the class....
For stock/17.5 or slower, the car is good out of the box. Only thing that will help are--
Front springs
Side springKing pin shims
Front end ride height shims
Spare body posts and additional bumpers
hanulec is offline
Old 12-09-2020, 12:13 AM
  #198
ospower's Avatar
Front springs
thanks!!!
ospower is offline
Old 12-09-2020, 12:14 AM
  #199
ospower's Avatar
any setup for gt12????
ospower is offline
Old 12-09-2020, 04:29 AM
  #200
hanulec's Avatar
A stock 1/12 setup is the same as a gt12 on foam tire setup
hanulec is offline
Old 12-09-2020, 03:06 PM
  #201
ospower's Avatar
ok thanks a lot my friend!
ospower is offline
Old 12-18-2020, 01:54 AM
  #202
ospower's Avatar
what bearings are you using for this car im having trouble finding a kit for it
ospower is offline
Old 12-18-2020, 04:42 AM
  #203
hanulec's Avatar
Info is in the manuals
front
Bearing 1/8 x 5/16, Flanged, 2 pcs
Rear
http://shop.rochercusa.com/index.php...scription=true
hanulec is offline
Old 07-15-2021, 05:55 PM
  #204
Anyone know what country Roche is based out of? Thanks
RCTVLIVE is offline
Old 07-15-2021, 08:39 PM
  #205
hanulec's Avatar
Design and manufacturer in Hong Kong
hanulec is offline
Old 07-16-2021, 06:40 AM
  #206
Thank you
RCTVLIVE is offline
Old 07-16-2021, 02:03 PM
  #207
fat500's Avatar
Trader Rating: 51 (100%+)
when is the new car coming?
fat500 is offline
Old 07-18-2021, 09:48 AM
  #208
hanulec's Avatar
Development car under testing....
hanulec is offline
Old 08-16-2021, 09:59 AM
  #209
trx-1racer's Avatar
Is there a ball diff kit available. I’ve got a US spec EVO coming and we run on a sanded epoxy concrete indoors. Bite is high, but not as high as carpet. Want to keep my options open.
trx-1racer is offline
Old 08-16-2021, 11:36 AM
  #210
hanulec's Avatar
Originally Posted by trx-1racer
Is there a ball diff kit available. Iíve got a US spec EVO coming and we run on a sanded epoxy concrete indoors. Bite is high, but not as high as carpet. Want to keep my options open.
yup
just search diff -- black and red colored are available
Rapide P12 Ball Differential Set
Rapide P12 Ball Differential Set, Black
hanulec is offline
