Like Tree2991Likes
1/12 forum
Old 07-13-2021 | 12:24 PM
  #48916
Bsthetech's Avatar
Originally Posted by DesertRat
What would you think the "ultimate" 1/12 car would be like? How would it be different from what we have today?
Awesomatix A12. Done.
Bsthetech is offline
Old 07-13-2021 | 05:34 PM
  #48917
ScottE1776's Avatar
WE NOW HAVE AN INDOOR ON ROAD TRACK IN MESA AZ - The old J.C Penny's home store in the Superstition Springs mall (not the regular JC Penny's that is still there). North East side of the mall, near Ulta and the Cheesecake Factory. Racing starts this Saturday (17 July) at 10 am - doors open at 8 am. See the ASR facebook page for more details.
ScottE1776 is offline
Old 07-14-2021 | 04:24 PM
  #48918
DesertRat's Avatar
Gotta re-assemble a touring car.
LonnyJ1950 and silden like this.
DesertRat is offline
Old 07-15-2021 | 11:56 AM
  #48919
fat500's Avatar
need a 1/12 car for asphalt....Options are pretty thin now. would prefer a roach.....Any ideas? Schumacher atom 2? thanks
fat500 is offline
Old 07-15-2021 | 11:58 AM
  #48920
fat500's Avatar
outdoor in florida
fat500 is offline
Old 07-15-2021 | 12:53 PM
  #48921
DesertRat's Avatar
Originally Posted by fat500
outdoor in florida
On asphalt, anything goes. 90-95% of the tuning of a pan car on asphalt is tires.
I would recommend a used car, something you don't mind getting scratched up, because it will be scarred.
eBay or the For Sale section may be a good source.
fat500 and silden like this.
Old 07-15-2021 | 05:56 PM
  #48922
nova2015's Avatar
Hi guys, I am running a Xray 2020 X12, outdoor asphalt, medium to low grip.
I am testing using a gear diff for the first time, and am finding forward traction on corner exit to be a problem. Has anyone had any success with the gear diff on asphalt?
Diff: 7k
Tyres: Fr Ulti J med, R Ulti Z Soft
Springs: Side and middle are kit, fronts are 375181 Silver ( one grade heavier than stock )
Thinking either a lighter rear spring or perhaps lighter diff oil?
nova2015 is offline
Old 07-21-2021 | 12:45 AM
  #48923
Hi guys,
So I purchased a 2020 x12 last indoor season, I thought the front was very well made however the shim system in the rear is a pain.
I was told I could swap rear pods with a better design from another brand, any recommendations?
Many thanks
Cepted is offline
Old 07-21-2021 | 03:33 AM
  #48924
choisan's Avatar
crc has the best rear pods (to me)
choisan is offline
Old 07-21-2021 | 03:53 AM
  #48925
simple's Avatar
Originally Posted by Cepted
Hi guys,
Many thanks
I still have a X12 '20 in my arsenal. I found the pain was worse when you try to change the shims on the rear pod with both hubs on the axle.
A simple technique that made my life so much easier was to remove the Left Rear Hub (one single screw that clamps the axle) and slide the axle out of the pod.
Everything is still intact and you can quickly and less painfully change the shims under the axle/bearing carriers.
Then, just make sure you slide the axle back into the pod before you tighten everything up.
silden likes this.
simple is offline
Old 07-21-2021 | 02:25 PM
  #48926
Fat500--- CRC CK25 ! Parts easy to get espcially if I'm around. Run GT12 it's fun and very competitive and the most popular 1/12th class in Florida.
BullFrog is offline
Old 07-24-2021 | 12:35 PM
  #48927
fat500's Avatar
Bullfrog thanks ordered a x12 and running gt12.
Really wanted to get a roche but nowhere to be found ... the X-ray was an Impulse Buy
fat500 is offline
Old 07-24-2021 | 04:22 PM
  #48928
Well at least your going to e running GT12. See you at the track.
BullFrog is offline
Old 07-30-2021 | 12:26 PM
  #48929
Default 1/12 overheating
I recently started racing 1/12 onroad 17.5. I’ve raced for years prior but not on black carpet... never before had a heat issue. But now on the black carpet it’s a little different story.. that being said others are running pretty much same gear, same rollout(different brand motor) and there temps are getting hot to(to much for me to be ok with). I’ve seen a few cars now (not locally) that have a fan on the back of the pod. I’m sure the air movement will help forsure ... so there any negative effects besides little more rear weight. Or a better idea to help cool it down a little without breaking the bank.. I’ve heard there is a motor out there that runs a lot cooler but doesn’t really have a can to it so it dissipates heat a lot better. Any suggestions
rcracersb is offline
Old 07-30-2021 | 01:32 PM
  #48930
DesertRat's Avatar
Newer spec motors are all higher RPM than previous generations. When before you could run a 17.5 rollout of 90-100mm, now 80 is generally a good starting point.
