Digital Servos from China
#286
I decided to compare the A86BHM, on the left, to the A80BHSW, on the right. The A80 is shorter, both in case size and motor length. The gears are almost identical although the A80BHSW servo spline gear does not have a pin to keep it from rotating 360 degrees. The A86BHM has a pin and a a slot that keeps it from rotating more than about 220 degrees. The encoder for the A86 cannot rotate continuously but the one for the A80 can, of course.
The A80BHSW has the encoder and the motor held in with the same white epoxy as in Bill's, so that's another difference from the A86BHM.
The board is identical to the A86BHM but, like on Bill's, the codes on the FETs has been removed so I can't identify them.
The biggest difference I noticed was the pin for the center gear. It's 2.0mm in diameter for the A86BHM and only 1.6mm for the A80BHSW.
#287
It's also worth noting that the FET's are considerably larger on the NitroPro servo as compared to the AGFrc servo.
So quick list of NitroPro upgrades that I'm aware of:
1) Upgraded FET's
2) Upgraded POT's
3) Upgraded circuit board and all the installed components
4) Redesigned case to prevent motor pinion gear from sliding off the shaft
5) Redesigned installation of the POT to prevent it from sliding out of place
Simply put, the pricing for the AGFrc branded servos is not worth what they are charging. spend the extra $40 to save you $80 of frustration, been there done that!
What's sad is that I considered selling the repaired servos, but I just can't in good faith pass forward these potential time bombs
1) Upgraded FET's
2) Upgraded POT's
#288
#289
Do yourself a favor and take a Lexus for a test drive, then you will quickly understand the differences that I'm talking about:
https://www.lexusgwinnett.com/2019-l...yota-camry.htm
Lexus is 302 / 203 = 49% more powerful among a slough of other features, no less different than the improved quality that NitroPro offers above AGFrc branded servos.
Yeah, I've been able to address some of the defects with the 40KG servos, but I've got a 36K (AGFrc) servo that still can't provide any load after resetting the pinion on the servo motor
#290
I raced for the first time since October last night.
I've still got the Blue Bird BLS-30A in my ebuggy. It's so quick and strong that I run it at 7.3V to tame it down a bit. Tons of crashes but it's still going strong and I took 3rd place in my main.
Still running a couple of AGF A80BHSW servos in my nitro buggy. Still no problems with them, either. Plenty strong and precise. Was able to take 3rd in my nitro main as well.
I'll try to remember to post updates when I race in order to find out how reliable these servos are.
#291
Servo update:
Couldn't race my nitro buggy with the AGF servos this past Saturday - not enough people - but I did race my ebuggy with the Blue Bird and my etruggy with another A80BHSW for steering.
The truggy broke a steering link in a tumble during the first round of qualifying, and I wasn't able to make my main, but the servo is still working well.
I took 3rd in ebuggy after a lot of tumbles and crashes with no problems from the servo. The Blue Bird is still doing fine and is more than fast enough on the lower voltage I run it on.
#292
CT1 update:
After 17+ race days the pin in the CT1 eventually snapped... not really surprised because that's about the only thing that hasn't been upgraded yet. I spoke with NitroPro and they are testing softer (more flexible) pins that should handle a little flex and be less likely to snap.
Although I could've sent the servo in for a free warranty replacement pin, I opted to make a quick repair myself and figured I would start my own testing by using a body clip which is the exact same 1.6mm diameter I need, and I believe these body clips are about as soft of a metal as I can get in this diameter
I've got 4+ race days with the repaired servo installed in my recently built E8T evo3:
https://www.rcgroups.com/forums/show...0#post46791599
I have already bought an SRT 9032 servo to replace the CT1 when the pin snaps again... only question is will it go longer than 15 race days with the softer metal???
Good news is that a snapped pin has never caused a DNF, but I make it a point to check for a locked servo after every race just to be sure as the symptom for a snapped pin. If you continue to use the servo after the pin has snapped, then you risk bending the shaft of the servo motor which could make the servo un-repairable... been there, done that with an AGFrc servo already
#293
Thanks for the update, Bill. If you're looking for something else (I know you just bought the SRT) I can't recommend the 2nd gen Blue Bird's highly enough. Just make sure it has soft start and stall protection like the BLS-30A does and you'll know it's one of the new ones. 1st gen had some issues but fortunately Flight Comp refunded me when mine failed.
#294
CT1 update:
I've got 4+ race days with the servo installed in my recently built E8T evo3:
#295
Key difference is that with NitroPro you get lifetime warranty on the servo gears, if you go with AGFrc, then it will cost you $33 after shipping to replace the pin yourself... or cut a body clip like I did for free
What I'm more interested is testing the theory that a softer metal in the pin will make it last longer and if the body clip repair stands the test of time, then the CT1 could be one of the best servos on the market for the price.
#296
I dont get why every servo needs an aluminum top case nowadays, for crawlers that often break servo cases due to the way servos mount sure .
A 1/8th car especially nitro imo its a stupid from an engineering perspective unless your designing something too both cost more and fail more often. lots of vibration + flex on a ridged mounted component the force has to go somewhere.
Full aluminum top cases and titanium servo gears are two things that pretty much ensure your servo will have a buttload of slop in short order.
how long do you think the ring and pinion would survive in a 1/8th with aluminum bulkheads? Exact same concept.
Machining the top case from carbon fiber would be just as dumb and twice as expensive to the consumer look for the manufactures to try that next for the guy that needs that extra .00001s a lap for his damn 17.5t 2wd buggy.
#297
+1
#298
They are necessary if you use flat head screws to keep the servo centered on the mount holes like this:
Time will tell if the body clip mod will hold up better, I trust NitroPro will sort it out soon and fact remains that NitroPro stands behind their product with a solid warranty unlike AGFrc. So long term cost on NitroPro is nil, but yes... long term cost to maintain AGFrc is astronomical
Regardless, all servos fail over time, typically the gears eventually wear out and having a lifetime warranty on the gears from NitroPro is priceless. The warranty on the SRT servos that I recently bought are only 1 year.... there's always going to be a trade off somewhere.
#300
https://www.youtube.com/watch?v=UnqcI0JkiUQ
215Likes
