Murnan modified mephisto 21 or Ielasi Raptor tuned 21 ? >
Like Tree6Likes
Old 04-13-2021 | 11:43 AM
  #16
BigC2007's Avatar
Originally Posted by YoDog
Most aftermarket modifications are pretty similar from people like Murnan, Rody and Ielasi. Some porting, crank timing and increased flow efficiency. Some are done by hand and others have CNC operations that increase productivity and lower cost for modified engines. The newer O.S. 2104 engines already have many modified features found in aftermarket engines. Murnan is US based so there is that factor to consider as well. Wallace Motorsports is the primary importer for Ielasi and typically have stock on hand once the initial release back orders have been fulfilled. If you are looking for a deal, look for versions from the last few years as they are typically very similar to the new flavors at a reduced price.
very good info here ! thanks
BigC2007 is offline
Old 04-13-2021 | 01:36 PM
  #17
I have seen many engines mostly OS and Novarossi based and those "modified" engines are mor like factory standard. If they have other timings then they are machined (even when they advertise with pictures of hand grinding). But if you have a direct link with the manufacturer with an own line of engines then the manufacturer just have to change some numbers in the CNC program, nothing as easy as that.
With OS from several brands I do see 2 types of crankshafts and basically the same timings on all sleeves (maybe 1 degree more or less). I do not know it all but to e it looks like there is not much or even no afterwork done. Also with all the piston issues on all 9 port OS based engines I do not believe "other" brands have different pistons.
Yes, the only modifiers like RBmods, EWmods, MAG, Murnan, DAP etc are the persons who do plenty af afterwork although I have never had such work in my hands. I do believe many people are very sensitive for the visual work and the "modified" text on the head. and willing to pay a lot for it
Roelof is offline
