Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree100Likes
Mugen MBX7R
Last edit by:
Print Wikipost
Old 02-06-2021 | 04:12 PM
  #3916
I've just purchased the air filter but no screw to hold the top hat in the packaging. What screw can be used to hold it down? Thanks in advance.
Exiger is offline
Old 02-06-2021 | 10:37 PM
  #3917
stanleyw808's Avatar
Hello Exiger,
It should be Flat Head M3x10mm..
Cheers..
stanleyw808 is offline
Old 02-06-2021 | 11:16 PM
  #3918
Originally Posted by stanleyw808
Hello Exiger,
Cheers..
Thank you so much!
Exiger is offline
Old 02-07-2021 | 08:37 AM
  #3919
whats “the top hat”?
Solico is offline
Old 02-07-2021 | 09:33 PM
  #3920
Hello Solico and Exiger,
I was assuming the "Top Hat" as the cap that holds the Foam Filter.
But I also realise that it will need another M3x8mm Button Head screw to hold the Air Filter unit to the Fuel Tank splash guard.
Cheers..
Solico likes this.
Old 03-02-2021 | 05:40 PM
  #3921
Default Carbon Fiber Front Plate
I have two Mbx7r
I’m making them both as identical as I can and am thus switching the front plate from M2C to this CF one.
my question is am I missing a spacer or something between the plate and the servo saver assembly? The other buggy that’s built with this CF plate looks like it has something there but the manual says there’s nothing supposed to be there.
which is right? I can’t take off the other’s plate at the moment because the screw is stripped and really rather not dremel it out until I need to.
Solico is offline
Old 03-03-2021 | 08:45 PM
  #3922
Hello Solico,
If You want to use Graphite/Carbon Upper Steering Plate, You need the Aluminum spacer like the one on the Bottom picture.
Cheers..
I have two Mbx7r
Solico likes this.
Old 03-04-2021 | 03:24 AM
  #3923
morgoth's Avatar
Yep, you need a spacers. The reason it's not in the manual, is because the original plastic part goes over the steering post. It basically has a build in plastic spacer.
If you get a flat carbon plate, you need to add the spacer. Usually the spacers are bundled with the CF plate if you bought it new.
Solico likes this.
morgoth is offline
Old 03-04-2021 | 05:11 PM
  #3924
Unfortunately I bought used. Does anyone have a part number or a reference I can use to check out where I can get one of those spacers? Also what’s a good way to know if my bevel gear or ring is too worn?
Solico is offline
Old 03-05-2021 | 10:26 PM
  #3925
Hello Solico,
The part would be E2121B - SERVO SAVER SPACER (For E2121)..
Most of the time Bevel/Ring Gear will last the lifetime of the Car when shimmed properly and greased when it is built for the first time and maintenance after that. I would say that You could take a picture of Your gear(s) and show to us here, then maybe we could give our opinion.
Cheers..
Solico likes this.
Last edited by stanleyw808; 03-05-2021 at 10:40 PM. Reason: Information addition..
Old 03-03-2023 | 10:43 AM
  #3926
Mickey_B's Avatar
Default Gearbox
Anyone know if the Mbx7 gear box will fit the Mbx8r?
Mickey_B is offline
Old 10-06-2023 | 04:49 PM
  #3927
Dal's Avatar
Dal
Default Battery Holder
Does the MBX8 battery holder, MUGE2327, Fit the MBX7 graphite plate?
Dal is offline
Old 10-08-2023 | 06:30 AM
  #3928
Not even close. Ive tried this already.
Dal likes this.
superathlete is offline
