Like Tree89Likes
Mugen MBX7R
    Hide Wikipost
Old 04-11-2017, 02:45 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX7R
Last edit by: E1 Diablo
Old 04-07-2019, 11:26 AM
  #3886
tom1974's Avatar
Originally Posted by frewster View Post
What spring would you recommend? I've been out of racing for years and I'm trying to relearn all of the tuning knowledge that I've lost. I'll admit that I'm rather clueless right now but I'm getting there.... Thank you for the advice.
9.0 front and 10.75 or 10.50 rear
frewster likes this.
tom1974 is offline
Old 04-07-2019, 11:32 AM
  #3887
tom1974's Avatar
https://www.hudy.net/xhudy/showfile.php?file_id=692&crt=e555ebe0ce426f7f9b2be f0706315e0c
tom1974 is offline
Old 04-07-2019, 11:41 AM
  #3888
frewster's Avatar
Thank you! I will try all that you have suggested.
frewster is offline
Old 05-05-2019, 12:52 PM
  #3889
frewster's Avatar
I do not recommend the Tworks steel shock standoffs. I had one of them snap off yesterday in a minor crash and since they don't use replaceable bolts it cannot be fixed.
frewster is offline
Old 05-08-2019, 04:51 AM
  #3890
hyperfuxx's Avatar
Trader Rating: 30 (97%+)
I had a older set that never had a problem with. Bought a new set for the 8 and they're a little short so when you tighten the nut down there's no play. Had to spin the nut around to get some slop. Tossed them and put the stock back on
hyperfuxx is offline
Old 07-08-2019, 03:32 PM
  #3891
Hey guys just getting back into racin, still got a 7r. I always thought the car needed some more steering. I was wondering if the "-3mm front upright arm" Part # MUGE2168, made a difference while on power mid/exit turning. Thanks for any advice
racingnewb is offline
Old 07-09-2019, 01:47 AM
  #3892
morgoth's Avatar
It's gives the car more overall steering. The entry steering is more aggressive and the exit is smoother and more predictable, but the you'll have more steering.
I have also found out that the -3mm steering plates allow you to run higher front diffs fluids so you gain a bit more on-power steering while still having enough turn in and mid corner steering.
morgoth is offline
Old 07-09-2019, 01:02 PM
  #3893
tom1974's Avatar
if you use this -3 you use e2147( more steering initial and more reactive)or e2146 (more steering in the middle and less reactive initially)
tom1974 is offline
Old 07-09-2019, 01:37 PM
  #3894
morgoth's Avatar
Always use E2146 with the -3mm plates. E2147 is too aggressive combined with the -3mm plates.
morgoth is offline
Old 07-09-2019, 05:07 PM
  #3895
Thanks Fella's, and thanks for mentioning part # E2146.
morgoth likes this.
Old 07-23-2019, 04:12 PM
  #3896
Hey guys, another question on the new uprights. I'm still using the universals, so what size bearing do I need since the 8x16 obviously doesn't work. I've spent way too much time searching the web for the bearing size. Thanks for any help
Old 07-24-2019, 12:25 AM
  #3897
morgoth's Avatar
It's 8x16x5 for univerals and 15x21x4 for the CVD's on the inside. The outside bearing is the same for both type of drivetrain and that's 8x16x5
morgoth is offline
Old 07-24-2019, 04:50 AM
  #3898
Wow I feel really dumb, I thought I needed a 8x21x5. I never even tried to fit the 8x16, I just figured i needed a bigger bearing. Thanks a lot morgoth
Old 07-24-2019, 05:00 AM
  #3899
morgoth's Avatar
No problem. The hubs should have a hole for a 8x16x5 bearing and a bigger groove for the 15x21x4 bearing.
If you have a normal mbx7 hub (not R) then, you can only run CVD's. The updated hub for the mbx7r and mbx8 accept both types of bearings.
morgoth is offline
Old 11-12-2019, 07:07 AM
  #3900
UrabusDenis's Avatar
Hi guys, could someone measure the distance between the front chassis holes at the front of the chassis? The ones which connect the diff housing at the front?
UrabusDenis is offline
