Like Tree2991Likes
1/12 forum
Old 12-24-2020 | 12:43 AM
  #48706
V12's Avatar
V12
Originally Posted by LonnyJ1950
Nope. Standard M3 are always a tight fit on BSR and CRC wheels. Serpent and I think Xray used to make special M3 cap heads with smaller diameter heads. Otherwise you run them in tight, turn them down a little yourself, or switch to a hub that uses 4-40 or M2.5 screws. Wheels from most other manufacturers don't have this problem.
Corally also made special M3 cap head screws.
V12 is offline
Old 12-24-2020 | 12:52 AM
  #48707
you are correct they are usually snug but the pair I just got are REAllY tight. I def need some small diameter head m3’s. Contact and some others are much more forgiving.
I had some of the corallys years back are they still available?
tnt2671 is offline
Old 12-24-2020 | 02:05 AM
  #48708
Robert K's Avatar
Originally Posted by yxiaocheng
I got a set of BSR tires with BSR rims, but the screw head was wayyyy too big (even for a normal screw)
What am I supposed to do? Should I be using a different screw to mount the tires? Or do I just have to live with this? Thanks.
Schumacher U7298 are made for these rims and have a "smaller" head
https://www.racing-cars.com/lmp-12/e...ption-parts%2f
Originally Posted by V12
OK thanks.
If I can find old CRC springs I will try the Schumacher and hope they fit the CRC spring retainer.
We used a lot of parts from older cars at our own Pro10 cars and most of the stuff is discontinued now.
They do. I used CRC, AE,Yoko and Schumi springs. All fit on the same retainer.
Regards Robert
Flygio and Juniorabca like this.
Robert K is offline
Old 12-24-2020 | 03:38 AM
  #48709
Regards Robert
Robert, thanks for that part # my local shop is a big Schumacher dealer so I’m sure he has them thanks again todd
tnt2671 is offline
Old 12-24-2020 | 07:18 AM
  #48710
EricF's Avatar
You can also use Associated #4732 - RC12R6 rear hub screw
EricF is offline
Old 12-24-2020 | 09:28 AM
  #48711
I use these, never had a problem after:
https://teameamotorsports.com/produc...ba478ad6&_ss=r
chensleyrc1 is offline
Old 12-25-2020 | 02:36 AM
  #48712
V12's Avatar
V12
Regards Robert
Thanks. So will try some Schumacher springs.
V12 is offline
Old 12-25-2020 | 02:44 AM
  #48713
V12's Avatar
V12
BTW is there any specific retainer which works the best for holding the springs.
I know I had one which was perfect and another one which was not that good but canīt remember which was which.
Long time gone since I build my cars or replaced a spring.
From what I remember I had the old CRC metal one the CRC plastic and the 12R5 retainer.
I think one of them was easy to replace a spring and hold perfectly.
V12 is offline
Old 12-25-2020 | 03:14 AM
  #48714
hanulec's Avatar
When in doubt, buy the spring retainer from that company. Always the safest bet
LonnyJ1950 likes this.
hanulec is offline
Old 12-25-2020 | 09:10 PM
  #48715
JeffofSpace's Avatar
What are general opinions of the Contact tires? I got a set of the us spec tires and am wondering how well they hold up to jft/bsr.
JeffofSpace is offline
Old 12-26-2020 | 05:58 AM
  #48716
Just run the tires and see what you think. I run CRC's only.
BullFrog is offline
Old 12-26-2020 | 07:10 AM
  #48717
Dan the Man's Avatar
I don't rate them. I've run them on grey ozite, ETS black and asphalt and they are nowhere near the Ultis that are the go to tyre here.
YMMV.
Dan the Man is offline
Old 12-26-2020 | 08:51 AM
  #48718
I'm thinking about getting back into carpet after a 20+ year hiatus. Is there a good source for setup info for 12th scale on-road? Kind of tough to muddle through over 3K posts, thanks ya'll
terrible is offline
Old 12-26-2020 | 01:34 PM
  #48719
terrible , lol i just went through the same thing took about 10yrs off of rc and just getting back into it , petit rc setup database has lots of setups from around the globe and from what i've seen and been told with alot of these newer 12th scales the kit setups are good enough to get you out there doin some laps. theres quite a few cars out there so i would just pick the one that floats your boat ( i went w/ the new awesomatix a12) which is really different from alot of whats out there i figured if im starting from scratch learning a car might as well try something different , but alot of the other cars are center spring , side spring and tube damper cars like which is the more tried and true platform. you prob already know there car specific threads on here to with lots of knowledgeable people willing to answer your questions and help out. the worst part is spending all the $$ rebuying everything you need if you sold it alll like i did , setup equip , tools ,tire truer etc but i guess thats all part of the fun. good luck and enjoy
tnt2671 is offline
Old 12-26-2020 | 01:46 PM
  #48720
hanulec's Avatar
dont buy anything
Go to your local track or hobby storeAsk for help
a12 is pretty different (but in a good way this far for 1/12 newbies) sorta hard to mess I up to much
hobbyten and NutDriver like this.
hanulec is offline
