Like Tree92Likes
OS R2104 engine Thread
Old 08-17-2020 | 10:45 PM
  #61
Slo-MTX4's Avatar
Has anyone that's driver a Max California also driven a standard/modified version of this? Whats the differences if any?
Slo-MTX4 is offline
Old 09-04-2020 | 11:06 AM
  #62
YoDog's Avatar
I think it's pretty much an RP9 with a low profile heatsink. That's about it.
Unless you race on a very high grip track, don't bother with the extra cost.
Maybe you are super critical about C of G. In that case, enjoy the benefit of a Low Profile Head.
YoDog is offline
Old 10-22-2020 | 06:23 PM
  #63
What is the manifold that comes with the O.S. SPEED R2104 WORLD CHAMPION COMBO?
wichitafc98 is offline
Old 10-22-2020 | 06:40 PM
  #64
YoDog's Avatar
MR03
YoDog is offline
Old 10-24-2020 | 01:39 AM
  #65
I just bought this motor from Rody. I will be running it in using the tuning bible method from here. I also will use an engine heater.
Its my first nitro ever... Does anyone have anything to add?
auxmash is offline
Old 10-24-2020 | 02:08 AM
  #66
You can also bring it over and do an oilbath break in.
But you you want to do it on the track. adjust the clutch to a low engage. It makes the car easy to run forward at a good rich setting and it will save the cluch shoe and aluminum clutchbell from a lot of slip and wear.
Roelof is offline
Old 10-24-2020 | 06:53 AM
  #67
Originally Posted by YoDog
MR03
thanks
Old 11-12-2020 | 05:44 AM
  #68
Has anyone tried the max power pipe and manifolds on the OSR2104 or OSR2102 or any other OS based engine?
if you have how does it compare to the OS pipes and manifolds .
rick oxley is offline
Old 11-17-2020 | 05:14 PM
  #69
YoDog's Avatar
Talking
I too am interested in this info.
YoDog is offline
Old 11-18-2020 | 12:35 AM
  #70
The MAX engines and the OS do share almost the same timings, there is only a slight difference in bore/stroke. I expect simular performances but can not tell which one is better. I know some who say the Novarossi 2015 also works good on OS engines.
Rick Vessell and davidl like this.
Roelof is offline
Old 11-18-2020 | 08:46 AM
  #71
dan_vector's Avatar
The OS guys usually use the Novarossi 2015 pipe for improved fuel economy if needed as far as I understand.
Rick Vessell likes this.
dan_vector is offline
Old 01-14-2021 | 09:46 AM
  #72
sinisterRC's Avatar
Hey fellas,
Looking to move on from Nova Rossi. Was looking at the GSR.21 9R. Any feedback? It's based off the OS 2104 correct?
Thanks!
sinisterRC is offline
Old 01-14-2021 | 06:28 PM
  #73
Originally Posted by sinisterRC
Hey fellas,
Thanks!
It's the same as the OS 2104. I have one and it works great.
Match it with MR02 manifold and TR02 pipe
Rick Vessell and madjack like this.
sonny8692 is offline
Old 02-01-2021 | 11:04 PM
  #74
3DFLYER's Avatar
hey guys,
please see attached pics.
This 2104 was ran in on the hudy stand for approx 1.25 Litres.
I then installed the engine in the car and slowly started running it in, even by the 4th litre of fuel it was still very right and I had it set still quite rich, I was Aiming for around 90-95°c during run in, while not to excessive load up or rev the engine.
​​The engine had a new glow plug, rod and fresh air cleaner before being installed in the car. I noticed this scratch at approx 4.5L and decided to remove engine and replace with another for racing following day.
What would cause this, and had this been seen before on the 2104?
Would you remove this piston and liner or just keep using it until it breaks now?
Thanks for any help
Hamish
3DFLYER is offline
Old 02-01-2021 | 11:45 PM
  #75
VS_Rody's Avatar
Originally Posted by 3DFLYER
hey guys,
Thanks for any help
Hamish
Looks like something has gone through the engine.
If you have not broken a glowplug then it could be wise to check the main-bearing.
To be honest, it does not look very bad either, if the engine has a good compression and has a good idle then I would not worry too much and use it as is.
3DFLYER likes this.
VS_Rody is offline
