Tekno RC ET410 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree469Likes
Last edit by:
Print Wikipost
Old 11-12-2020 | 08:23 AM
  #1126
Originally Posted by sea1swk
In a way I did. I had a et410. Then built up a eb410.2 to a et410, then when the et410.2 came out, upgrade a couple extra parts to make it a entire et410.2. I liked how it drove. I did end up with the "A" steering in it. Took some work to make it fit. It gave me tighter steering in the 180" corners. I think the ".2" is more for fixing some issues with strength. Main driving changes are the front hubs and solid support for the rear shocks in the front of the rear arms.
Did you notice a need to change spring or shock oil in the rear switching to the forward mounted shocks?
tkvtec is offline
Old 11-13-2020 | 05:42 AM
  #1127
HOTROD716's Avatar
Depends on the track, but I have been on the same track and layout, and I switched to the .2 pistons. It is a lot smoother, for me. I also went down in the rear sway bar and springs for more of a rotation in the tighter turns. Overall, .2 setup stock to stock, feels more responsive in turn section.
HOTROD716 is offline
Old 11-13-2020 | 11:07 AM
  #1128
Awesome, thanks for the feedback!
tkvtec is offline
Old 11-14-2020 | 09:18 AM
  #1129
Anyone tried this???
https://prostarrc.ecwid.com/EB410-&-...ions-p98850755
inlinesick is offline
Old 11-17-2020 | 08:05 AM
  #1130
HOTROD716's Avatar
I have their sct conversion. I added a stick pack and finishing up a few things. Tightens up the front a bit, yet offers flex as well. Best I can relate is when the top brace was offered for the Yokomo 870c. I think the prostar piece is more of a tuning aid.
Old 11-17-2020 | 11:34 AM
  #1131
sea1swk's Avatar
I ran a et410/Cobra chassis SCT for a long time. Never ran a special middle brace, it rocked. The new Prostar SCT is better, as you can switch to front or rear bias. I thing the Prostar middle brace looks cool, but don't feel it is a must have. Maybe a big outdoor track, with monster power? I have not tried that yet. This year, my track is pretty limited with the plague. So SCT has been dead. I do love the et410.2 updates on it though. 3.5 hinge pins. Rear aluminum brace on the bulkhead, good stuff.
sea1swk is offline
Old 11-30-2020 | 03:14 PM
  #1132
platgof's Avatar
I just installed the 3.5 pins, and that is a must do on this rig. As I pulled out the old front arms and pins, sure enough the pins were all bent up. Part #'s are TKR 6544B, 7225B, and 6523. Not to expensive, and easy to do. I bought mine from AMain and used their box to prop it up, how cool is that! Took 15-20 minutes. Those 3 mm are just to weak for this little beast.
platgof is offline
Old 12-27-2020 | 08:24 PM
  #1133
Dryrain's Avatar
got these a few days ago on an impulse buy. so lazy to put it together.
rustyus likes this.
Dryrain is offline
Old 01-29-2021 | 07:15 AM
  #1134
Thinking of adding truggy to run indoor 4wd truggy on foams. Anyone have an idea on what the normal product release cycle is for Tekno? I don't really want to buy something that is going to have a new version out in the next 2 months.
Silverbullet555 is offline
Old 01-29-2021 | 07:35 AM
  #1135
tobamiester's Avatar
Highly doubtful any updates to the ET410.2 anytime soon. it just came out last summer (2020).
Silverbullet555 likes this.
tobamiester is offline
Old 01-29-2021 | 07:48 AM
  #1136
Thank you. That is very helpful. Should be at least a year. Tempting to pick one up.
Important upgrades to get?
Old 01-29-2021 | 08:09 PM
  #1137
What are the "necessary" hop up parts I should order? I bought one today on an impulse with a coupon.
Old 01-29-2021 | 08:25 PM
  #1138
Dryrain's Avatar
I think the aluminum servo horn and aluminum shock caps are essential. The rest are just for show. After a month I stop at bag L cause it was a lot of work putting it together. So tired..
Dryrain is offline
Old 01-29-2021 | 08:49 PM
  #1139
Tired due to covid or life?
Is it reasonable to change to 48p spurs?
Old 01-29-2021 | 08:55 PM
  #1140
Dryrain's Avatar
tired after each bags or saw no desire to continue on. I think I'll finish it up when summer hit.
why change the spur? the stock one is fine.
Dryrain is offline
