Sanwa-compatible receiver thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree130Likes
Last edit by:
Print Wikipost
Old 09-27-2020 | 06:29 AM
  #181
Nicadrauspro4's Avatar
I just bought this. It's already here but haven't tried it yet. Pretty cheap for $30.
Anyone tried this before?
TheSilverSpider likes this.
Nicadrauspro4 is online now
Old 10-05-2020 | 01:29 AM
  #182
Lonestar's Avatar
Commenting here as I'm on the market for a couple of extra Rx's for my M17, so I figured out I could add to the thread
I have a few races of offroad EP (mod 4wd, so lots of constraints!) with the slidelogy - and it worked perfectly. FH4T.
I have just installed the dasmikro in a 12th scaler, the package is soooo tiny it's amazing - seems to work ok on the bench, I have yet to try it in real life. FH4T too.
Lonestar is offline
Old 10-05-2020 | 06:07 AM
  #183
QuietStorm1122's Avatar
Default Might be a question already answered
I just got a sanwa 482 receiver for my m17 radio and I got two issues
one the plugs for everything trying to get into the receiver are very tight battery plug will not go in without really forcing it.
and two I not sure how to bind it to my radio. I put in a batter into the receiver and get no light when I push the bind button. Can someone help me.
QuietStorm1122 is offline
Old 10-05-2020 | 07:27 AM
  #184
rustyus's Avatar
Default Binding
No instructions with the Sanwa RX-482 receiver? That's weird. Should be able to use the following to get you where you need to be...
Nicadrauspro4 and tomthegeek like this.
rustyus is offline
Old 10-10-2020 | 01:38 AM
  #185
Bit of sanding on the connectors, front and back. Less so on the sides. I've noticed this on my 482 too.
Skynet5 is offline
Old 10-10-2020 | 01:40 AM
  #186
Dasmikro is brilliant. Works at my local track no problem, although I actually just use it for vrc Pro in reality.
If it had a bind button...
Skynet5 is offline
Old 10-10-2020 | 09:51 AM
  #187
Bsthetech's Avatar
I take an Xacto and whittle them down.
Bsthetech is offline
Old 10-15-2020 | 09:12 PM
  #188
alana07's Avatar
Anyone knows whether these Sanwa compatible receivers can work with the Exzes Plus transmitter? I was using the original Sanwa DSSS 2.4ghz module previously, and now wanting to get a couple of receivers for new cars but keeping with the Exzes Plus tx. Appreciate any advice given.
alana07 is offline
Old 10-16-2020 | 05:43 AM
  #189
Once I got it binded, I have had zero problems at my local tracks.
wely324 is offline
Old 10-16-2020 | 08:30 AM
  #190
I never had a receiver with a bind plug before... but It's actually kinda convenient to install the receiver without needing to leave access to the button.
mushroomed is offline
Old 10-24-2020 | 05:00 PM
  #191
ollie 45's Avatar
how do you bind them without a button? Like the Spektrum?
ollie 45 is offline
Old 10-24-2020 | 05:48 PM
  #192
Correct, it has a bind plug like some Spektrum receivers.
Old 10-26-2020 | 12:03 AM
  #193
Just got the ARX482 from Banggood. About USD30. It works really well, so far. Its just going in a Tamiya rere Boomerang as a sometimes runner but all good so far
I've had the dasmikro ones for a few months now and they are working well. I ended up putting one in my FF racer because I couldn't be bothered swapping a Sanwa one out of another car and it went well at a club day
jgil089 is offline
Old 11-12-2020 | 06:51 PM
  #194
ollie 45's Avatar
I cant get my DasMikro to bind to my M12.. go to bind on the radio, bind icon flashes and arrows start moving, RX flashes blue rapidly and nothing, acts like it isnt receiving anything
ollie 45 is offline
Old 12-21-2020 | 12:07 PM
  #195
Goof's Avatar
I got mine off ebay works great
I used a rx pack to bind it..
I put my remote in to bind like u did then i plug in the rx battery to rx port then i push the bind button again on the radio then the rx light went soild
Goof is offline
