Sanwa-compatible receiver thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree130Likes
Last edit by:
Print Wikipost
Old 08-03-2020 | 02:07 PM
  #166
Originally Posted by abailey21
Is anyone making knock off Futaba receivers?
Why? when Futaba receivers are dirt cheap compared to the Sanwa.... they are like $50 https://www.hobbytown.com/futaba-r20...tl7604/p222749
Phillip F is offline
Old 08-12-2020 | 05:20 PM
  #167
I got my DasMikro in the mail today and I think it may be DOA. No instructions were included, anyone know what the procedure is to bind it? I'm using a MT-S. When I plug the esc in and power on i get no blue light.
wely324 is offline
Old 08-12-2020 | 07:38 PM
  #168
rustyus's Avatar
You used the bind plug on the receiver. Right?
rustyus is offline
Old 08-13-2020 | 07:55 AM
  #169
Yes, the bind plug was already plugged in.
wely324 is offline
Old 08-17-2020 | 06:09 PM
  #170
I got a replacement Dasmikro rx and it seems to be the same issue. I have my esc plugged into channel 2, power on and I get no led to blink or light up on the RX???
Does anyone know the exact procedure for binding a unit like this with a bind loop plug?
wely324 is offline
Old 08-17-2020 | 07:08 PM
  #171
I'm so frustrated with the Dasmikro neither of them powered on, so I wanted to swap my Sanwa RX482 and i think I just fried it.
edit: figured it out, wiring on the plugs was causing it not to power on.
wely324 is offline
Old 08-18-2020 | 09:51 AM
  #172
CL's Avatar
CL
Nevermind...
CL is offline
Old 08-19-2020 | 01:00 AM
  #173
Just got mine today. 8 days to the UK.
Plug bind cable into last port. Turn on tx and set to bind. Plug in Rx. Leave 10seconds. Done.
I'm just using it for VRCpro.
I'll get an SMD as a spare for the track.
So far really impressed for £20 delivered.
jgil089 likes this.
Skynet5 is offline
Old 09-10-2020 | 01:58 PM
  #174
I just bought an RX-472 from a forum member. Didn't buy it for telemetry but it does show voltage without any add-ons. I'm set at 6 volt but can run at 7.4 volt with the servo I have. At 6 volt the telemetry is useless because I never go that low. Would it make sense to run at 7.4 and then I should see anything below that on my transmitter display? I know it's a little tougher on the servos from what I've heard. Am I making sense?
Milkdudd is offline
Old 09-10-2020 | 10:04 PM
  #175
DirkW's Avatar
IIRC it shows only BEC voltage, not battery voltage.
DirkW is offline
Old 09-11-2020 | 04:51 AM
  #176
I appreciate the response. Actually this brings up a subject I have wondered about for quite a while. If you set your BEC at 7.4 volts what happens when your actual battery voltage goes below that, dropping all the way down to 6.4 volts or so before cut off. Wouldn't the BEC drop anytime you had less than 7.4 volts in the battery? Thanks
Milkdudd is offline
Old 09-11-2020 | 05:28 AM
  #177
it never gets that low in competition
Stevie S is offline
Old 09-11-2020 | 10:21 AM
  #178
Thanks for responding. Mostly I do open practice sessions at a couple of race tracks in my area. I usually take two or three cars and it's nice to know when my battery starts getting low. I'd rather pull them off the track before the cutoff kicks in
Milkdudd is offline
Old 09-11-2020 | 01:16 PM
  #179
for competition all cut offs are disabled and practice sessions are timed the same as the qualifiers but during extended practice I never use the cut off and pull at the very first sign of a fade but very rare to go that long
Stevie S is offline
Old 09-16-2020 | 08:05 AM
  #180
Any direct replacements to use on a Mini Z or do you have to hack it to make work? I have seen people do it, but it's murky at best...any insight? I'd love to use my M12 with my Mini Z's! Thanks!
maxwellduryea is offline
