Like Tree2Likes
  • 2 Post By the rc guy
80 amp esc help
Old 08-12-2020 | 04:06 PM
chazekxt's Avatar
Default 80 amp esc help
hey all I picked up a off brand 80 amp esc the paper work on the esc say's not to use 3.1 default cut off non protection.. the program card has 3.1 2.9 and 2.7so which one should I use?
chazekxt is offline
Old 08-12-2020 | 04:41 PM
the rc guy's Avatar
2.9 then get a battery buzzer in the correct voltage you want your lipos be at
the rc guy is offline
Old 08-12-2020 | 05:23 PM
chazekxt's Avatar
ok will set it to 2.9 thanks
chazekxt is offline
Old 08-12-2020 | 05:37 PM
If it says cut off "non protection", I'm assuming this means that it's disabled/turned off. Voltage selection wouldn't matter then. (jmo)
Andy Koback is offline
Old 08-12-2020 | 05:47 PM
chazekxt's Avatar
yes it say's non protection default 3.1 v so I guess at 3.1 there is no lvc?
chazekxt is offline
Old 08-12-2020 | 06:59 PM
What I'm thinking.
Old 08-13-2020 | 06:37 AM
will you post a link or pic of the manual? I'd like to see how the wording is expressed visually, perhaps in a chart? Could be Chinglish issue where they might be missing a comma, if so, then LVC may be disabled by default, and they might be recommending 3.1V instead.
billdelong is offline
Old 08-13-2020 | 03:19 PM
chazekxt's Avatar
will try
chazekxt is offline
Old 08-13-2020 | 04:05 PM
the rc guy's Avatar
well ???
Old 08-13-2020 | 04:07 PM
Non protection is just one of the settings. The 3.1v cut off is default.
Roelof is online now
Old 08-14-2020 | 03:46 PM
chazekxt's Avatar
i know this 3.1 is non preotection so i dont use the 3.1 ? right? go with 2.9?
chazekxt is offline
Old 08-14-2020 | 04:18 PM
No, he means non protected is a option to select, and 3.1 is another and how it is set to from the factory. 2 different settings.
Steve8 is offline
Old 08-14-2020 | 05:51 PM
the rc guy's Avatar
not sure why you think the 3.1 v setting is not protected .. Its the wording from there language to english... so it has all those voltage listed they are protected . but it does have a non-protection mode.
set it to 3.1 you will be safe
Andy Koback and dtr like this.
Old 08-15-2020 | 08:17 AM
chazekxt's Avatar
ok thanks will try that
chazekxt is offline
