80 amp esc help
hey all I picked up a off brand 80 amp esc the paper work on the esc say's not to use 3.1 default cut off non protection.. the program card has 3.1 2.9 and 2.7so which one should I use?
will you post a link or pic of the manual? I'd like to see how the wording is expressed visually, perhaps in a chart? Could be Chinglish issue where they might be missing a comma, if so, then LVC may be disabled by default, and they might be recommending 3.1V instead.
not sure why you think the 3.1 v setting is not protected .. Its the wording from there language to english... so it has all those voltage listed they are protected . but it does have a non-protection mode.
set it to 3.1 you will be safe
2Likes
