Fuel Leak at the Inlet to the Carb >
Old 08-08-2020 | 02:41 PM
Default Fuel Leak at the Inlet to the Carb
Hello everybody, I am having issues with fuel leaking out of the inlet to the carb. I have never seen this issue before, and I am not sure how to go about fixing it. The inlet is tight, and the fuel line fits tightly on the inlet nipple. I checked for burs on the washer/inlet stack, and did not find any. The engine is new, and was leaking right away. The only idea I had was to order new washers. I would like to know if anyone has any other tips for sealing up this leak? I am not sure if I can apply sealent/grease etc. to this area to get a good seal. Any help is appreciated!
IOP_Racer is offline
Old 08-08-2020 | 03:19 PM
No crack/damage to the fuel line?
I would claim warranty if it is new.
Roelof is offline
Old 08-08-2020 | 04:46 PM
Losi215's Avatar
what kind of kit or engine is this and is it? As Roelof said below, claim a warranty if it’s new for sure. I also think replacing the washers Is a grand idea even if you didn’t run the engine yet. Maybe the fuel line or fuel nipple assembly is cracked itself from over-tightening from the factory? Not sure about alternative sealing methods. Hope you get it fixed
Losi215 is offline
Old 08-08-2020 | 07:07 PM
I have never hear of a warranty on an rc product... I guess the engine is not technically new anymore since I had to run it to notice the fuel leak. The engine is an Nova Rolling. If the new washers dont work, I have a carb I can swap on to it and hopefully the engine will run good either way.
Old 08-08-2020 | 08:25 PM
the rc guy's Avatar
if its a novarossi you have 30 days to return for defective product due to defects in manufacturing or workmanship..
Returns
the rc guy is offline
Old 08-09-2020 | 03:37 AM
On all products you have a warranty, for sure when you can prove it is no abuse. Broken parts with signs on a runned car is for sure no warranty. A leaking carburator right after buying is a reason for waranty, not that you can get your money back but for sure they need to assist you with solving the issue under warranty.
Roelof is offline
Old 08-11-2020 | 10:06 AM
Take the fuel banjo and some 600 sand paper. Lay the paper on a flat surface and with your pointer finger in a circular motion polish up both sides of the banjo.
vigorcs90 is offline
