Like Tree1Likes
  • 1 Post By Roelof
2s Lipo Battery
Old 07-10-2020 | 11:34 AM
vannon's Avatar
Default 2s Lipo Battery
Hello, I have a 2s lipo that has removable leads. My question is do I only need to have this lead connected when it is charging? Reason because the battery strap covers this hole on my EB410.
vannon is offline
Old 07-10-2020 | 11:54 AM
Ominex's Avatar
You only need it when charging, not needed when running the car.
Ominex is offline
Old 07-10-2020 | 12:02 PM
That 2mm connector is for balancing the cells, so yes, it is needed.
Roelof is offline
Old 07-10-2020 | 12:28 PM
Geezatec's Avatar
+1 on Ro and Om
Geezatec is offline
Old 07-10-2020 | 12:42 PM
the rc guy's Avatar
center hole only needed for balancing.not needed for esc...
the rc guy is offline
Old 07-10-2020 | 03:15 PM
However, IF you want to balance charge your lipo while in the car, you will need it ... can you just drill a hole in the battery strap where it interferes? ...
tomkatn is offline
Old 07-10-2020 | 04:31 PM
I just got a near mint maclan Lihv uses that 2mm so in a sense to save time it is best to get the charging cables as well. I can make a set, I hope the seller put it in with the battery.
Juglenaut is offline
Old 07-11-2020 | 12:20 AM
Is charging in a LiPo bag not mandatory? And if not, it is safer for yourself in case something goes wrong while charging.
Juglenaut likes this.
Roelof is offline
Old 07-16-2020 | 10:40 PM
Donīt worry bro, if you are not running you donīt need that
quiannzo is offline
Old 07-18-2020 | 12:15 PM
mrreet2001's Avatar
It's not balancing when you are running.
The only car I have ever use the balance port while running was because it had a cell alarm on it.
mrreet2001 is offline
Old 07-18-2020 | 07:53 PM
Kent Beal's Avatar
I would not charge the battery in the car, ever. Of all my racing since 92' the only three times I saw a lipo catch on fire at a race facility in the pits was mounted in the car. By the time all was said and done, the battery, esc, rx, servo and chassis were a complete loss. Just not worth it.
Kent Beal is offline
