Which type of wire should I use for this PCB? >
Like Tree9Likes
Old 07-06-2020 | 06:17 PM
  #16
gigaplex's Avatar
Originally Posted by Dave_S
Did you ever link pictures, i can't see anything.
Not enough posts to do that
Dave_S likes this.
gigaplex is offline
Old 07-06-2020 | 06:21 PM
  #17
Dave_S's Avatar
I see. Was just trying to get a better idea of what you are doing. I've modded controllers and used to do PCB component level work.
Dave_S is offline
Old 07-07-2020 | 10:42 AM
  #18
Yeah. I can't still post url or images.
steelseries 3gc is the controller I want to make this project with.
masusaca is offline
Old 07-07-2020 | 11:37 PM
  #19
Dave_S's Avatar
If you want you can email pics to me at [email protected]
Dave_S is offline
Old 07-08-2020 | 01:35 PM
  #20
Dave_S's Avatar
I would probably use ribbon cable if i had some, but after seeing pictures i think most wire recommendations will work
Dave_S is offline
Old 07-08-2020 | 03:17 PM
  #21
If those buttons return a resistive value when pressed, then making the wires significantly longer might cause the controller to not recognize the buttons. If the controller is looking for a specific resistive value and the added length of wire changes the value enough, it won't see the correct value when the button is pressed. Do you have a multimeter or more preferably an oscilloscope? Without knowing exactly how the controller works, nobody can give you accurate advice. Those wires are small, so they do not carry significant current, but without more information we're all just guessing at this point.
masusaca, what are you trying to make where you need to move these buttons off the controller?
Bry195 likes this.
waitwhat is offline
Old 07-08-2020 | 03:26 PM
  #22
PDR's Avatar
PDR
Depending on:
1) Where you are
2) How long you want to extend it
I'd recommend this stuff: https://www.adafruit.com/product/3892
It's 4-wire, but just peel off one of the wires to make it three. It's beautiful to work with, very flexible and the insulation doesn't melt with over enthusiastic soldering. Adafruit can do good shipping out of NYC and there are distributors in many parts of the world. That pack is trimmed to 1 metre, so if you need longer, it might be awkward.
PDR is offline
Old 07-08-2020 | 04:20 PM
  #23
the rc guy's Avatar
4 wire is outa stock pdr. id go with what I said...
the rc guy is offline
Old 07-08-2020 | 05:27 PM
  #24
I'm trying to make a steering wheel and move those button below the table for a pedal I'm making.
masusaca is offline
Old 07-08-2020 | 05:29 PM
  #25
About 3 feet.
masusaca is offline
Old 07-08-2020 | 06:08 PM
  #26
PDR's Avatar
PDR
Obviously go with what you can lay your hands on. Might be browser weirdness, but I see 4 of the 26AWG/4-wire in stock. Here in Oz there's some local suppliers that I can normally get small quantities next day. Would love to track down longer lengths of the 2/4/10 wire variants.
PDR is offline
