Like Tree92Likes
OS R2104 engine Thread
Old 01-31-2020 | 12:38 AM
  #46
VS_Rody's Avatar
Originally Posted by LAGuy
How often do you need to replace the rod. Just picked one up. Looking forward to running it!
It is advised to change to rod after each 5 Liters of fuel run trough the engine. Of course you can run longer but you also take more risque then.
VS_Rody is offline
Old 01-31-2020 | 08:05 AM
  #47
That's what I do with mine, 1 1/2 to 2 gallons.
nitrodude is offline
Old 03-01-2020 | 11:34 PM
  #48
Default 2104
Hey guys struggling to get my liner out.. any tips on how to do this would be much appreciated
*RC-ADDICTION* is offline
Old 03-02-2020 | 01:23 AM
  #49
Leave the flywheel on, ty-wrap through the exhaust and turn the flywheel over untill the lip is sticking above the crank case.
VS_Rody likes this.
Roelof is online now
Old 04-09-2020 | 07:26 PM
  #50
Stupid question from someone moving from electric touring cars to 1/8 Nitro pan cars ,,
With this motor straight out of the box can I use 25% Nitro ?
Also what glow plugs will I need in the tool box ?
What is the deal with head shims ? Should I just leave that shit alone ?
Thank you in advance
BPR Racing is offline
Old 04-10-2020 | 12:38 AM
  #51
VS_Rody's Avatar
Yes you can use this engine out of the box with 25% nitro and you need to use RP7 glowplugs with this engine.
When using this engine in a 1/8 Pancar you do not need to change the headshims because you will never be able to use all the power available.
I personally think this engine is overkill for a pancar and you can do with a less expensive engine, unless you just like to do this
VS_Rody is offline
Old 04-28-2020 | 01:49 AM
  #52
Looking to replace the connecting rod on the OS Speed R 2104 ,,
Is it the same as the R 2103 connecting rod ?
Part number im looking at buying is 23755020
Thank's in advance for the help
Old 04-28-2020 | 02:12 AM
  #53
VS_Rody's Avatar
Yes, conrods of the R2101/02/03/04 are all the same.
Part# 23755020 or 23755024(including 3 piston retainer)
Rick Vessell likes this.
VS_Rody is offline
Old 05-30-2020 | 02:01 AM
  #54
Default 2104
Hey guys ive been running 16% from new, done about 4L. Want to go 25%, should i change anything or just re tune to suit? The engine is stock..
Old 05-30-2020 | 06:15 AM
  #55
dan_vector's Avatar
It would be a good idea to add a 0.1mm head shim when going up to 25%. The engine might not need it but best to play it safe and add the shim initially and see how it goes.
Rick Vessell and VS_Rody like this.
dan_vector is offline
Old 06-03-2020 | 02:56 PM
  #56
RC MARKET's Avatar
New OS TR02 Pipe Set
RC MARKET is offline
Old 06-24-2020 | 04:27 PM
  #57
PROVK's Avatar
What is the difference between front bearings 23731000 and 23731020 as they are the same size?
PROVK is offline
Old 06-24-2020 | 11:19 PM
  #58
VS_Rody's Avatar
Both have the same dimensions.
23731000 has a black protection and normally used for the on-road engines.
23731000 has a blue protection and normally used for off-road engines. The blue protection is a little tighter on the inner-ring so seals a little better.
VS_Rody is offline
Old 06-25-2020 | 02:02 AM
  #59
PROVK's Avatar
Thanks Rody
VS_Rody likes this.
PROVK is offline
Old 06-26-2020 | 03:50 AM
  #60
choisan's Avatar
to me, this is talking about info and help, not an ads. thanks rody
Rick Vessell, jasoncsc and VS_Rody like this.
choisan is offline
