Like Tree92Likes
OS R2104 engine Thread
Old 12-06-2019 | 11:14 PM
  #31
VS_Rody's Avatar
Originally Posted by BP Vortex
For me it's only interesting how they did this two color anodizing... Which masking lacquer do they use... 😅?
First you do the black anodizing, then you re-work the sections which you want to have the other color(in general lighter then black), then again you do the anodizing for the lighter color.
VS_Rody is offline
Old 12-07-2019 | 12:18 AM
  #32
Yes yes that's all clear... The problem is to get the right lacquer to cover the anodized parts... And as a machinist cnc programmer etc. I can see that the red anodized areas are machined after they covered the black areas... Not that easy.
It can be easy but you need the right masking stuff
I guess😅
BP Vortex is offline
Old 12-07-2019 | 04:00 AM
  #33
Not sure if a black anodized layer needs to be masked with a lighter color used for a 2nd proces but if so then I think a liquid mask is used.
It is a lot of work just for the awesome looks, I wonder if a plain head or a 1 color head can make a price difference.
Roelof is offline
Old 12-07-2019 | 05:48 AM
  #34
From my experience you can't dye a brighter color on a darker. The reason us that the acid would solve your black first anodizing. So you have to cover the black color up. The head got 5operations 6 with the laser engraving.
That's my thought
Old 12-26-2019 | 01:45 PM
  #35
PROVK's Avatar
Is the R2104 WC special edition any different apart from the cosmetics?
PROVK is offline
Old 12-27-2019 | 12:13 AM
  #36
VS_Rody's Avatar
No, it is all the same inside. Except for the manifold, this one is not yet available.
PROVK likes this.
VS_Rody is offline
Old 12-27-2019 | 01:53 AM
  #37
PROVK's Avatar
Thank you
PROVK is offline
Old 12-28-2019 | 01:26 AM
  #38
Default 16%
Hey guys it says in the manual that it has .1 and .15 gasket for 25% fuel. So if i want to run 16% do i add a .1 shim?
*RC-ADDICTION* is offline
Old 12-28-2019 | 01:37 AM
  #39
VS_Rody's Avatar
If you are running 16% nitro and on a short track you can remove the copper shim(0.1mm), but in general we leave the original setting just to play it safe.
VS_Rody is offline
Old 12-28-2019 | 05:35 AM
  #40
Or replace the 0.15 gasket for a 0.1 one,
VS_Rody likes this.
Roelof is offline
Old 01-14-2020 | 09:14 PM
  #41
Hey guys what size collet do i need to remove the rear bearing?
Old 01-14-2020 | 10:49 PM
  #42
VS_Rody's Avatar
14mm
VS_Rody is offline
Old 01-28-2020 | 01:22 PM
  #43
carkillaii's Avatar
At the 2019 1/8 WC I did witness first hand that O.S was the Faster Engine , My question & concern how is the longevity of the O.S Engine , How often will I have to replace the P&S?
carkillaii is online now
Old 01-28-2020 | 01:33 PM
  #44
It lasts, when you think its done, it will just keep going. Just replace the rod at regular intervals.
carkillaii and Who like this.
nitrodude is offline
Old 01-30-2020 | 10:35 PM
  #45
How often do you need to replace the rod. Just picked one up. Looking forward to running it!
LAGuy is offline
