Sensor board's sensor replacement >
Old 03-31-2019 | 06:15 PM
Default Sensor board's sensor replacement
Hi all,
is someone here ever changed bad sensors on sensor board ???
I want to make a test and the only thing is missing is a sensor.
I already know:
Supply voltage : 5VDC
SOT-23 case
Digital Latch Hall effect sensor type needed (What i suspect to be good, not sure)
Open Drain Output
High frequency banwidth
High magnetic sensitivity
If i'm in error or someone already has a part number , don't hesitate !!!
Thanks !!!
TheRay57 is offline
Old 03-31-2019 | 07:00 PM
Ill tell you soon. I just ordered some.
Bry195 is offline
Old 03-31-2019 | 07:01 PM
Do you reemeber which company made them ??
TheRay57 is offline
Old 03-31-2019 | 07:45 PM
I just ordered the ones that looked dimensionally correct. Only one set of smd Hall effects for sale on ebay under rc cars. Mine are damaged and I ordered a complete replacement board and figure i could solder these on and if they worked they worked. They are the right voltage too.
5 bucks and nothing to lose. i have a solder station for smd so the work shouldnt be too bad either.
Bry195 is offline
Old 06-10-2019 | 08:30 PM
Did you make the test??
TheRay57 is offline
Old 06-10-2019 | 11:05 PM
If you just visit Farnell you can select the product group, add some filters and all possible options pop out.
Roelof is online now
Old 06-11-2019 | 06:25 AM
Visiting Farnell or mouser website is the easiest part of the job !!
There's a lot of sensor's type for those sensor : Omnipolar, Unipolar, Switch, Latch, Positive South, Positive North (Inverted). It's necessary to have the good type.
You also have to know the supply voltage, Output type, etc.
Not an easy task !!
TheRay57 is offline
Old 06-11-2019 | 09:42 AM
You do need a latching hall sensor working on 5 max 6v (BEC voltage) and in this case a SOT23 housing
Open drain or open collector output is not realy needed.
Old 06-11-2019 | 06:13 PM
Keep Digi-Key in mind, they carry all sorts of components and other stuff.
Newark Element 14
Allied Electronics
Jameco Electronics
Arrow Electronics
Just to name a few.
Juglenaut is offline
