Can someone with a Spectrum DX5R take a look at there Tx for me real fast? >
Old 06-11-2019, 08:18 PM
Kepner's Avatar
Default Spectrum DX5R antenna connection.
EDIT: I've solved the issue with tech support. The correct spot is the one that is closer to the light of logo or considered farther away from your body while holding it, however you look at it.
​So...took my radio apart to add a built-in charge port and I unplugged the antenna from inside the radio. Well.... When I was putting it back together I noticed there were two spots to plug the antenna back into the board. Which one am I supposed to use? You can look at that spot in the radio simply by undoing the one screw below the lighted logo.
Is the spot I have it in right now during the picture correct or is it the other spot above in the picture?​​​​​​ Edit, the answer is no. The other spot.
Kepner is offline
Old 06-11-2019, 08:55 PM
R/C Tech Elite Member
lowspark's Avatar
Take it out and give it a try in the street. If it works your good. If not try plugging it in the other spot...
lowspark is offline
Old 06-11-2019, 09:33 PM
Kepner's Avatar
That is absolutely the wrong answer. You never ever want to turn a transmitter on without an antenna attached. This goes for anything that transmits a signal, cb radio, fm transmitter. Doing so will almost certainly cause damage to the amplifier because there is no load to dissipate the signal.
Kepner is offline
