Awesomatix A800/A800R >
Like Tree2289Likes
    Hide Wikipost
Old 03-29-2023, 11:28 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800/A800R
Last edit by: hanulec
A800R Released March 23, 2023 with two kit versions, A800RA (alloy) and A800RC (carbon)
Mid Motor Content ---
New Part Releases
  • January 2020 - A800-AM24-20 Servo Holder - combine servo holder and steering holder to one single part.
  • February 2020 - A800-ADC Advanced Damper Cup Set - Reduces the amount of rebuild routines. It offers the possibility to A) remove air and B) add oil into the damper without the need of full disassembling
  • January 2021 - A800-BDL - Body Downtravel Limiter, replaces SPR08
  • March 2021 - A800-P138LFA - 38T Pully Low Friction - For Gear Diff
  • March 2021 - A800-P138S-LFA 38T Spool Pulley Low Friction - For Spool
  • April 2021 - A800-C27MMX - Full Length Top Deck for A800MMX
  • May 2021 - A800-C01MMA Alloy Chassis - Battery position is shifted to the front to achieve a better overall weight distribution. Removes short arm holes. New narrower shape
  • September 2021 - A800-C04M1+7.0 Arm - narrows the track width for lower grip levels
  • October 2021 - AM180EVO Single Bellcrank Steering Update - AM180EVO is a direct replacement for AM180M5
A800MMX and A800MMXA Kit Updates
  • AM152/AM24-8 is replaced by AM24-20 in this kit (UPDATE 08.03.2021)
  • P138/P138S is replaced by P138-1/P138S-1 in this kit (UPDATE 25.03.2021)
  • C01B-X-MMA is replaced by C01MMA in MMXA kit (UPDATE 26.05.2021)
  • AM180M5 is replaced by AM180EVO in this kit (UPDATE 21.09.2021)
Below OLD Rear Motor Content ---
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 02-14-2019, 10:39 PM
  #3886
Trader Rating: 33 (100%+)
Quick question: Are the P45R’s meant to be reusable?
I took a couple of my dampers apart tonight and noticed the P45R’s fell out when removing the vanes from the damper body. Then after cleaning everything and going to reinsert the P45R into the vanes they just fell right in, like they shrunk. Is this normal?
rgirocz28 is offline
Old 02-15-2019, 02:15 AM
  #3887
Default P45R fór D2.1
Good morning awesomatix people,
Can I use P45R in D2.1 dampers without problems, or do I need to buy some more parts?
desaix is offline
Old 02-15-2019, 05:35 AM
  #3888
Cavity in D2.1 rotor is not deep enough for P45R.
Oleg Babich is offline
Old 02-15-2019, 07:58 AM
  #3889
Trader Rating: 40 (100%+)
Does AT142 comes in a pack of 4?
joech is offline
Old 02-15-2019, 08:16 AM
  #3890
http://shop.awesomatix.com/index.php?productID=1256
Old 02-15-2019, 08:32 AM
  #3891
Thanks Oleg. I should have looked at both Awesomatix site.
joech is offline
Old 02-17-2019, 04:40 PM
  #3892
Default USA kit availability
Any idea when more kits will be available? What kit would be the best starting point for CRC black carpet in USA?
John
DrFelter is offline
Old 02-17-2019, 05:46 PM
  #3893
hanulec's Avatar
Trader Rating: 28 (100%+)
John
Next week...
Either of the alloy kits
hanulec is offline
Old 02-18-2019, 03:47 AM
  #3894
mac853's Avatar
Could someone tell me if RCmaker and USA Awesomatix accept credit card payment, please?
Ggrant likes this.
mac853 is offline
Old 02-18-2019, 09:23 AM
  #3895
RC maker does ! Don't know about those Yankees
Ggrant is offline
Old 02-18-2019, 12:17 PM
  #3896
hanulec's Avatar
CC via PayPal processor at AwesomatixUSA
hanulec is offline
Old 02-18-2019, 12:55 PM
  #3897
mac853's Avatar
Ok, thanks!
mac853 is offline
Old 02-19-2019, 12:40 PM
  #3898
Kodey65's Avatar
I took mine apart after a few weeks and it was the reverse...they p45r appeared to swell a bit. So I re-used them.
Kodey65 is offline
Old 02-19-2019, 12:41 PM
  #3899
Kodey65's Avatar
Hello all...well looking to build my first MMCX....any advice before I start?
Kodey65 is offline
Old 02-21-2019, 04:24 PM
  #3900
Kodey65's Avatar
Originally Posted by Mr. Bubby
I'm very curious about the flexible caster blocks for this car. Has anybody tried them out? It seems that they've always been on backorder but they are available on the Awesomatix website. Can't really seem to find any information on the benefits of this. Or are there any benefits?
Also on that same note, kinda, is the Adjustable body mount set, always seems to be on backorder but I can definitely see the benefits of this. But as for the flexible caster blocks, just not sure about the benefit. If anybody can chime in on this, would be much appreciated. Thanks.
I found the ABS but have yet to try it out. I'll report back when I set up. One thing to note is that you'll also have to find an older P-14 bumper set - The newer versions have 4 built in posts vs 2 on the older P-14.
Kodey65 is offline
