Tekno RC EB48.3 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree22Likes
Last edit by:
Print Wikipost
Old 10-06-2018 | 08:34 AM
  #2986
suzukipro's Avatar
Originally Posted by ReV:-O
Are there any spur gears smaller than 44T? I can't find any
KKPIT (chinese knock off manufacturer) had actually made some high quality machined nylon 43T spurs that were designed for the Tekno, but I have been unable to find them the past couple years.
suzukipro is offline
Old 11-17-2018 | 01:22 PM
  #2987
1/8 IC Fan's Avatar
Hi, will the Tekno EB48.2 body fit on the EB48.3?
Yes, as will the EB48 original onto the EB48.3
1/8 IC Fan is offline
Old 01-31-2019 | 05:09 PM
  #2988
ok guys I look and looked and can't find a solid list on what it will take to move a eb.3 to a complete .4 I know it is not going to be cost effective but can it be done.. and if so a parts list would be incredible.. thanks in advance I know some one out there has this info..
BIGTRUX is offline
Old 01-31-2019 | 05:36 PM
  #2989
RCSteveH's Avatar
the main difference are the overdrive F/R diffs, the bearings in the steering hubs and Ackerman.
RCSteveH is offline
Old 01-31-2019 | 07:48 PM
  #2990
Just off the top of my head the major things that are different;
-chassis
-front and rear arms
-front and rear drive shafts
-steering Ackerman/geometry
-front and rear ring and pinion gears
-front spindles
I think they list the differences on the website; https://www.teknorc.com/shop/tkr8000...ed-description
Honestly, I like my .3 just fine still!
Tbuggy is offline
Old 01-30-2020 | 12:48 PM
  #2991
How much radial movement is acceptable on the center diff bearings? Mine still turns nice and smooth but there is what seems to be too much movement. I never saw it new so I don't know if amy movement is normal. Mine is really loud at speed and I had thought this was due to the steel spur gear but now that I have seem this movement I think it could also contribute to the noise and probably doesn't help the wear characteristics either.
So, is there a spec on what I should see? I haven't put a guage on mine but I would guess that there is 0.5-0.75mm.
RaceBash is offline
