Sanwa-compatible receiver thread
#346
My version 2 492 clone is not having bec issue so far.
but i will buy the sanwa latest version instead if i buy again
https://sanwa-denshi.co.jp/rc/car/receiver/rx-49t.html
#347
I had a similar issue with my v2 clone and a Savox servo (power hungry and known for brownouts). Adding a cap into the receiver fixed this issue for me.
#348
i have 3 of these off amazon, NO issues.. ARX-482R 4CH FHSS
https://www.amazon.com/ARX-482R-Inte..._0_1_ec_i&th=1
#349
I picked up a Das Mikro rx and it works great on FH3. Had a problem with DH4 and could care less. I bought two RX-472 that would not bind, and at least this one does. I will not buy another new or used RX-472 when I know this one will work. Plan on buying at least one more. I checked the range and it is fine, over 200 feet. I had a rough week having two rxs fail and a soldering iron, but all is good now as I replaced them.
#350
I just received two AGF ARX-482R that I ordered from Banggood, came in under $50 and both the packaging and the units are very nice.
I have the das mikro ones as well, and the AGF is much better build quality.
A very nice bonus feature is that this receiver actually supports SSL telemetry for my Sanwa ESC when plugged into the BATT port.
This is not mentioned in the instructions or marketing materials explicitly, but worked when I tried it just now.
Motor temps and RPM are coming in crystal clear, I haven't tried ESC settings yet though.
was you able to to do telementry with all the ESC settings as well after testing further?
130Likes
