Sanwa-compatible receiver thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree130Likes
Last edit by:
Print Wikipost
Old 11-25-2023 | 06:10 PM
  #346
choisan's Avatar
My version 2 492 clone is not having bec issue so far.
but i will buy the sanwa latest version instead if i buy again
https://sanwa-denshi.co.jp/rc/car/receiver/rx-49t.html
choisan is offline
Old 11-26-2023 | 04:29 PM
  #347
Sanchez's Avatar
Originally Posted by gigaplex
My Dasmikro 492 v2 clone arrived today. It has the same issue as the previous one, radio brownouts on my car with a weak BEC. My genuine Sanwa FH5 receivers as well as my 482 clones all handle the same test just fine.
I had a similar issue with my v2 clone and a Savox servo (power hungry and known for brownouts). Adding a cap into the receiver fixed this issue for me.
gigaplex likes this.
Sanchez is offline
Old 12-10-2023 | 06:21 AM
  #348
platgof's Avatar
Originally Posted by jabroni racing
i have 3 of these off amazon, NO issues.. ARX-482R 4CH FHSS
https://www.amazon.com/ARX-482R-Inte..._0_1_ec_i&th=1
why does it say futaba
platgof is offline
Old 12-19-2023 | 11:37 AM
  #349
platgof's Avatar
I picked up a Das Mikro rx and it works great on FH3. Had a problem with DH4 and could care less. I bought two RX-472 that would not bind, and at least this one does. I will not buy another new or used RX-472 when I know this one will work. Plan on buying at least one more. I checked the range and it is fine, over 200 feet. I had a rough week having two rxs fail and a soldering iron, but all is good now as I replaced them.
platgof is offline
Old 09-08-2024 | 07:10 PM
  #350
Originally Posted by Xtracrispy
I just received two AGF ARX-482R that I ordered from Banggood, came in under $50 and both the packaging and the units are very nice.
I have the das mikro ones as well, and the AGF is much better build quality.
A very nice bonus feature is that this receiver actually supports SSL telemetry for my Sanwa ESC when plugged into the BATT port.
This is not mentioned in the instructions or marketing materials explicitly, but worked when I tried it just now.
Motor temps and RPM are coming in crystal clear, I haven't tried ESC settings yet though.
was you able to to do telementry with all the ESC settings as well after testing further?
TheSilverSpider is offline
Old 02-09-2025 | 02:14 AM
  #351
endy0430's Avatar
Default 1/10 scale on road
What’s the best receiver for on road touring car fwd club racing to pair with the M17
endy0430 is online now
Old 02-09-2025 | 04:05 AM
  #352
The one that works with the M17?
Roelof is offline
