Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 10-15-2018 | 09:49 AM
  #1771
Bikerbob's Avatar
Hey all, just built a TT02 Raikiri and the front end seems sloppy - there is slop or droop in the front suspension.. but the rear there is not. Is this normal? Do I want that "droop"?
James
Bikerbob is offline
Old 10-15-2018 | 11:04 AM
  #1772
wtcc's Avatar
The stock box setup will be fine. The front droop is strange, but comes from the design of the hubs (compared to the rear, where the hubs have some kind of stopper). So you can spend a lot of money to upgrade to a Type S with tuning parts or buy oil shocks (plastic from Tamiya) and use o-rings below the piston to reduce the droop.
wtcc is offline
Old 10-15-2018 | 11:21 AM
  #1773
Bikerbob's Avatar
Thanks Wtcc, but the class we are running is BOX STOCK - with bearings only. SO this is the way it must be.
James
Bikerbob is offline
Old 10-27-2018 | 07:14 PM
  #1774
Raman's Avatar
Ive been curious as to what Tamiya did to make an oil filled TT-02 diff.. seems not much!!! It uses
1. Gasket from TG10 Mk.2
https://www.tamiyausa.com/shop/tamiy...-diff-case-pk/
2. Black 5 mm o-rings which can be found everywhere
3. Metal gears from TG10 Mk.2 as well
4. Metal cross shaft..
Pretty easy stuff.. wish we had this info long ago.. I bet it will leak easily but better than nothing
DaSilva3525 likes this.
Raman is offline
Old 11-08-2018 | 08:29 AM
  #1775
TIME MACHINE's Avatar
I just purchased a TT-02 White Edition and find myself like a fish out of water. I plan to use this for some parking lot racing, nothing fancy or organized.
Can anyone offer advice on what KV range I should be looking at? I'm going to buy a cheap sensored combo, since I won't need anything fancy. Will the stock motor mount be an issue? Should I just automatically order the Yeah racing upgrade?
TIME MACHINE is offline
Old 11-08-2018 | 12:42 PM
  #1776
Raman's Avatar
If it’s organised parking lot racing, then they will tell you what motor to run ..
i recommend Hobbywing just stock and one of their motors
Raman is offline
Old 11-12-2018 | 11:06 PM
  #1777
Theibault's Avatar
Default Yeah Racing Tamiya TT-02 Aluminum Conversion Kit Abridged Build
I've always wanted a full bling kit, even though running one will probably result in a broken chassis lol.
Theibault is offline
Old 11-13-2018 | 08:03 AM
  #1778
$200 for the kit of parts. $100 will get you one of three double deck belt drive chassis. I'm... not sure this is a good idea.
Theibault likes this.
Nerobro is offline
Old 11-13-2018 | 09:58 AM
  #1779
LJH
https://youtu.be/nh8eHm4cXdA
Putting lipstick on a pig....LOL
Cheers,
Jim
LJH is offline
Old 11-13-2018 | 02:36 PM
  #1780
Raman's Avatar
I want that Sub Imprezza body but Tamiya didn’t release it as a body set.. you can buy the body for $34 and the decal sheet for $32, no idea where to find that plastic parts spru lol.. or buy the TT-02 kit for $118 (tower coupon) and have a spare car lol.
Raman is offline
Old 11-13-2018 | 03:03 PM
  #1781
To get a new body and wheel set for my M05, I bought a complete second M05. Then sold the assembled chassis. I ended up paying $40 for the body and wheels.
Nerobro is offline
Old 11-13-2018 | 03:06 PM
  #1782
Raman's Avatar
I’m tempted to go that route. Where did you sell it? Here or EBay?
Raman is offline
Old 11-13-2018 | 10:25 PM
  #1783
Theibault's Avatar
I have about 100 cars. I've never had a useless shiny pretty car and I wanted one lol. It's not going to be run much, but it will get a Sunday drive here and there.
Old 11-13-2018 | 11:07 PM
  #1784
Ebay. It worked out pretty good for me. :-)
Nerobro is offline
Old 11-19-2018 | 02:30 PM
  #1785
thirtydaZe's Avatar
subscribed.
thirtydaZe is offline
