XRay X10'18
#33
Does anyone have a good starting setup for running the X10 2018 in WGT-R on black carpet?
Using the supplied 96T spur, what pinion range can you run? I'm worried I may not be able to get a large enough pinion on. I was running a smaller spur on my CRC. (Motiv MC2 17.5 on 1S). Anyone else's spur gears work on the X10?
I'm ditching my CRC Gen-X 10R/T for an X10 to accompany my X1.
#35
#36
Went and made some changes this weekend that helped the car a lot. Went to the stiffest side spring, narrowed front track with the 1mm eccentric cams, mounted a set of front tires low profile style which narrowed the front 4mm further, and widened rear to the maximum 200mm. The car has much more turn in now which is what I was severely lacking before.
17Likes
