Like Tree7Likes
  • 1 Post By airbiscuit
  • 2 Post By skater-deez1
  • 1 Post By Sir 51D3WAYS
  • 1 Post By PPM RC Racing
  • 1 Post By riceball777
  • 1 Post By Roelof
64p vs 48p
Old 04-02-2018 | 04:21 AM
Default 64p vs 48p
Lets say there is 2 rc car. Totally the same inside out BUT one is geared with 64p gearing & anothet is geared with 48p gearing.
So which car will be faster?
JCG1 likes this.
airbiscuit is offline
Old 04-02-2018 | 04:40 AM
Tino Valachi's Avatar
64p would be my first choice and faster , It’s commonly used by everyone ,
on other hand your 48p could be twice as fast as you’re 64p if the gearing is right ?
Tino
Tino Valachi is offline
Old 04-02-2018 | 05:11 AM
tooth strength ,,, reason 32 p was popular for dirt...
64 pitch is smoother then both... less friction.
speed is very debatable... just more gearing choices..
I run 64p.. carpet and dirt... cause I have over (25) 64 pitch pinions...
chuck_thehammer is offline
Old 04-02-2018 | 06:14 AM
skater-deez1's Avatar
Thumbs up
Gear pitch alone will NOT make one faster than the other. Tooth strength is greater on 48p than 64p as mentioned above. Same rollout......same speed. 64pitch will be a little more quiet and smooth sounding but no faster.
SouthFloridaApp and JCG1 like this.
skater-deez1 is offline
Old 04-02-2018 | 10:54 AM
Darkgenerals's Avatar
64p also offers more fine tunning option.
Both are equal speed wise, your gearing based on rollout not on equal tooth count.
Darkgenerals is offline
Old 04-02-2018 | 07:27 PM
Generally, 48p is 1/10 offroad while 64p is onroad. The 48p teeth are bigger and stronger while 64p teeth are lighter and smaller (weaker). On short course it really depends on the car you have.
+1 Norcal Hobbies Tino Valachi
rcbuggy88 is offline
Old 04-02-2018 | 11:03 PM
Thanks for the replies guys.
I am still thinking of either changing to a 64p or stay with 48p. The reason I am asking is that I am currently doing off roading only, so 48p is common in my toolbox.
I am now going on road too, its either I make my on road setup standard as my off road (48p) so less headache in stocking my pinion & spurs as I can used the same pitch on either of my rcs.
Or just go for 64p on road but this will make me shop new sets of spurs & pinions.
I never bother about speed & such for off road as I just enjoyed my rc time off road. No race no nothing. So now I am thinking for my on road rc, which will be faster? Same FDR, setup & all, 48p or 64p.
Old 04-03-2018 | 02:27 AM
my guess is money......
number of 48p gears.. in your tool box...
on-road is almost always 64p... as gearing is important.. and 64p gives you the most .
an on-road cars has limited space for spur/pinion sizes.
but you would NOT be the first with 48p on a pan car...
Old 05-26-2018 | 02:30 AM
Sir 51D3WAYS's Avatar
Gear ratio is independent of gear pitch. If both cars have the same gear ratio, they would theoretically have the same speed. (In practice I suspect 64 p might be very, very slightly faster, due to less friction, but I've never tried. I also suspect you wouldn't really feel it unless you were some kind of pro.)
Personally I'd stick with 48p, unless you are running a pan car.
48p is also stronger and easier to set mesh if you have bad eyesight like me / are new to rc.
Seeing that you already have 48 pitch gears, why not save yourself the money and spend it on hopups/electronics?
SouthFloridaApp likes this.
Sir 51D3WAYS is offline
Old 07-15-2018 | 12:01 PM
PPM RC Racing's Avatar
I think 48p is more suitable for beginner because it is easier to adjust the position between pinion gear and spur gear.Also,i think it is more durable than 64p.
When I was using the 64p,i think the 64p have better acceleration(my own feeling)and it is more silence than 48p.
airbiscuit likes this.
PPM RC Racing is offline
Old 07-19-2018 | 01:37 AM
i like 48 pitch for both onroad and off road
skater-deez1 likes this.
riceball777 is offline
Old 07-20-2018 | 04:33 PM
Thumbs up
Exactly, there's something to be said for durability in the gear department......you can't win if you don't finish.
Old 07-20-2018 | 10:01 PM
Just use a sheet of paper to set your mesh?
This isn't rocket science guys.
Old 07-21-2018 | 12:30 AM
On paper 64dp would be better due the smaller tooth contact giving less resistance. The difference is nevertheless very small. Add to that the total rotating mass and resistance of the drivetrain and wheels and the difference will fade into nothing.
Roelof is offline
Old 09-04-2018 | 03:28 AM
Off-road I would go for 48pitch unless I need finer gearing ratio to suit the motor/track.
rccartips is offline
