How do they get away with it! >
Like Tree11Likes
Old 02-07-2018 | 02:30 PM
  #46
Originally Posted by RC*PHREAK
if the first gear "rarely" strips, why are the replacements sold in 3 packs?
Traditionally we have always sold the replacement 1st gear packs in a 3 pack because chances are if a racer is managing to strip the first gear on the track, then he will probably succeed in doing it again at some point. Despite this, we still hardly ever sell 1st gears for any of our servos, and I dare say because most of our servo users are actually airplane guys..
Xpress.. is offline
Old 02-10-2018 | 08:59 PM
  #47
ljl23's Avatar
Originally Posted by platgof
Stripped a gear in my Savox and replaced the gears, good to go. Savox is all metal and they strip as well.
Some of the cheaper savox servos state they use metal but they are actually brass gears. It's kind of a gimmick, and I agree that they shouldn't use the word metal.
ljl23 is offline
Old 02-10-2018 | 10:05 PM
  #48
gigaplex's Avatar
Are you not aware that brass is a metal?
DirkW, Xpress.., tvih and 1 others like this.
gigaplex is online now
Old 02-10-2018 | 11:17 PM
  #49
I rather have brass than plastic
grabbem88 is offline
Old 02-11-2018 | 07:42 AM
  #50
whitrzac's Avatar
Originally Posted by billdelong
On the JX servos I've been running, it's the second gear that is stripping, but the first gear also starts to show signs of wear, the following is a sample gear that has seen 14+ months of racing in a 1/8 buggy when I started to notice some slop forming under the servo arm and this is what I found, though technically the gear hadn't stripped yet, you can see the sharp shark teeth toward the top:
I had noticed that the grease in the gears was all black and gritty, I almost wonder if it would've been a better preventative to regularly clean the gears and re-grease them, thinking that might allow them to last longer. The servo on the right is a brand new donor servo for a fresh set of gears and fresh grease.
I have servos that are probably old enough to drive by now, I have never seen a gearset get that worn out.
whitrzac is offline
