-   -   How do they get away with it! (https://www.rctech.net/forum/radio-electronics/1009533-how-do-they-get-away.html)
2wheeltyson 02-02-2018 07:11 AM
Recently I've had 2 servos fail (my 10 year old daughter is just learning). These were sold as "metal gear servos" but upon inspection they both have a plastic "fail gear". I call B.S.
buggybattle 02-02-2018 07:45 AM
Who is "they" also what model servo ? I would not be shocked if the lower end servos 50 and under are built like junk ha
2wheeltyson 02-02-2018 08:50 AM
They are 2 different "big name brands" they were budget (around $50) advertised as "metal gear"
Darkgenerals 02-02-2018 09:37 AM
You do understand you can say the name right? Snap some photo's of the servo and the broken gear. everyone one loves good carnage pictures.
Igottabeme 02-02-2018 09:52 AM
Name and model of servo? What are the servos being used in?
peter george 02-02-2018 09:55 AM
I too would like to know who they are ? If they lied I would send it back
the rc guy 02-02-2018 09:55 AM
are you running a servo saver? get 1 then your failures might stop. contact company and submit return for what you purchased..
buggybattle 02-02-2018 10:16 AM
Well that's not very helpful. Sorry you had bad luck.
MarkA 02-02-2018 10:17 AM
Very few cars can even run a servo saver anymore and with all the all-aluminum steering racks that are now more common, buying an all-metal gear servo is often essential.
Thus...
Or this thread is kind of pointless.
Kaifd3s 02-02-2018 10:20 AM
Patiently waiting for the name and model of the servo.
Roelof 02-02-2018 10:44 AM
It is for some brands common that the 1st gear after the motor pinion is plastic. I believe the Multiplex Tiny-S mg has such a construction.
Over there the gear does not need to hold a lot of power and it is a failsafe....
2wheeltyson 02-02-2018 11:16 AM
The first was a hitec 5925 and the second was a spektrum S6020 both were in 1/10 buggy.
kaistas 02-02-2018 11:20 AM
I've opened a spektrum S6240, and they indeed had a metal gear. I'd be interested to know what model.
2wheeltyson 02-02-2018 11:43 AM
Spektrum's description
KEY FEATURES
146 oz-in torque at 6V affords impressive performance in the toughest applications
Precise digital control
Dual ball bearings provide less resistance for higher performance and longer life
Heavy-duty metal gear train
2wheeltyson 02-02-2018 11:46 AM
Then the funny fine print
Gear Type:MetalGear Material:Metal with one (1) plastic
