Tekno RC EB48.4 Thread
#1381
Thanks for the part#, but was hoping to find some aluminum spacers
0.5mm of slop on each side... I've got some Durango spacers that are 0.2mm thick but no good posting that part number because they're out of business, hopefully Tekno can fill the gaps (pun intended) for various shim spacing options
#1383
So I want to try Ryan Lutz's setup because he recently raced our current track layout and I figured it would be something worth trying, however he's only got his nitro setup posted:
http://lutzinator.com/wp-content/plu...2011-12-17.pdf
Do folks generally think this would be close enough to the electric version or would the nitro setup be too far off?
One thing I couldn't help but to notice was that he marked CVD's in his setup, is this simply because the nitro kit come with CVD's by default?
My kit comes with universals and I saw the following note posted on the OP:
My track is smooth so my question is whether it really makes any difference on a smooth track because the note only talks about bumpy conditions and doesn't really explain why one option is better for which condition.
#1384
Much appreciated for the feedback, I'll start with the universals because that's what the kit comes with, but I'm failing to understand what advantage the CVD will offer over universals on a smooth track for the rear? Does it add more traction, etc?
#1386
Okay that helps, and makes sense... thanks for the explanation. I think I read that the .4 arms are different so I assume the shafts are different as well, meaning I can't simply swap out the CVD's from my .3 buggy to try, I'll need to buy the .4 CVD's right?
#1387
John
#1388
Thanks John, I assume this is the same John I raced with last night with our EB410's on the Jr track
I'll go ahead and pick up some CVD's for both the front and rear then, and plan to run the universals when the time comes. Really enjoying this build so far, hopefully this cold weather passes through soon so I can paint some bodies!
#1389
#1390
Okay, I think I'm going blind... but for the life of me I can't seem to find anywhere on the setup sheet which lists the front wheelbase adjustment, I can clearly see the rear wheelbase settings toward the bottom center of the setup sheet but I got nothing for the front. With the previous .3 release, this was a fixed setting but on page 12 of the instructions it shows a TKR5165 (2mm spacer) placed toward the front which shortens the wheelbase for a more aggressive setup (I assume) per the box stock setup?
Does anyone know what the pros are doing with this tuning option for a smooth medium grip track? Curious if anyone is splitting this spacer up with 1mm on each side of the spindle, etc?
#1391
#1393
For rear wheelbase, i've maked specific aluminium shims. 1.5mm and 4.5mm with the same diameters of originals parts. Not much wear if there is no burr. But for sure, plastic is the best choice for durability.
For front wheelbase, be careful about the gap between driveshaft and spring's damper...It's very close if the carrier is on the front. So, i don't think it's a good idea to change it, but.....
For driveshaft, the general rule is: rough tracks = UNI, smooth track= CVD
#1394
Seems like they have switched to adding vehicle specific advice in the instruction manuals instead.
311Likes
