Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 11-27-2017 | 07:44 AM
  #7816
Originally Posted by Jwilliams5
Try reversing the throttle channel. If that fails to work up the endpoints for the throttle channel. I have never messed with that esc before. But on some combinations of esc and radio the endpoints do not go far enough at 100%. So increasing the endpoints to the max may help solve this issue.
Thanks. I tried that. I ran into a guy over on B6 Nation that had the same issue and his had to be sent back to AE. I'm calling them shortly.
frdtrkguy is offline
Old 11-27-2017 | 07:53 AM
  #7817
Bit of a random question but nevertheless I would like to know the answer: Completely stock, is the B6D a better car than a completely stock B5M? The answer to this question is important because it would tell us whether the B6 platform is actually an improvement over the old car, when the laydown transmission is left out of the equation. Everyone knows the laydown tranny is great on the right surface, but there really is nothing to compare it to as every car on the market (afaik) is on their first gen car with the laydown tranny.
Side question: Does anyone who the first company that ever ran a prototype laydown tranny on a modern chassis was?
Fearo is offline
Old 11-27-2017 | 08:57 AM
  #7818
Davidka's Avatar
I didn't run a B5m, but I really do like the B6d in stock form. I have not felt the need to convert to laydown, even though just about everyone at my track has been on it since they came out.
I believe the Yokomo YZ-2 and Xray XB2 were the first production laydown cars. I recall someone getting the Yokomo and hating it at first.
Davidka is offline
Old 11-27-2017 | 09:11 AM
  #7819
There is no simple answer. But the short answer is yes the B6d is a better platform than the b5m. The tuning window is much larger. For the most part the durability is improved as well. I can say that the arms from the b5/b5m fit this car as well. The new arms have 3 mounting holes in the front and the tears have the same 2 holes except on both front and rear of the arms. I had a bunch of flat and full b5 series arms in my pit box. So what I did was drill the third hole in all of them. Now I’ll never need front arms lol.
Jwilliams5 is offline
Old 11-27-2017 | 09:16 AM
  #7820
mschumi101's Avatar
Didn't Schumacher and Xray first do a forward motor? Like basically a 4wd chassis with no front drivetrain/different kickup and shock towers. Not sure if those classify a "laydown" but definitely some of the first carpet based 2wd mid-motor platforms.
mschumi101 is offline
Old 11-27-2017 | 09:19 AM
  #7821
Oh yeah, Schumacher had belt drive mid-motor car YEARS before the current crop of laydown cars, but those are totally different. I was referring to the 3 gear laydown tranny most of us now consider as standard.
Fearo is offline
Old 11-27-2017 | 12:05 PM
  #7822
Wildcat1971's Avatar
Tech Prophet
New tower from Avid 4.5mm thick.
B6 Carbon Shock Tower | 4.5mm | Gullwing Front Accessorie AV1082-GF
Wildcat1971 is offline
Old 11-27-2017 | 09:54 PM
  #7823
Im sure this has been answered in here somewhere but I can't find it. Im looking at doing the schelle rear hubs with the 67mm cva light conversion axel set. Can I used the standard hex or do I have to change that too?
FPMX772 is offline
Old 11-27-2017 | 10:14 PM
  #7824
yes. use your standard wheel hex.
Phillip F is offline
Old 11-28-2017 | 07:09 AM
  #7825
OK cool, thanks!
FPMX772 is offline
Old 11-28-2017 | 06:50 PM
  #7826
https://www.amainhobbies.com/st-raci...1400bk/p387022 is this fit for b6?
raved007 is offline
Old 11-28-2017 | 06:59 PM
  #7827
No. The B5 and B6 caster blocks are different. Look similar, but not cross compatible
Chris Brown is offline
Old 11-28-2017 | 07:20 PM
  #7828
raved007 is offline
Old 11-28-2017 | 09:39 PM
  #7829
Stobert2012's Avatar
Do the B6’s ordered now have the updated chassis?
Stobert2012 is offline
Old 11-28-2017 | 09:54 PM
  #7830
Matt Trimmings's Avatar
Unless its old stock at a hobbyshop....I ordered from amain about 2 months back and it had the updated chassis.
Matt Trimmings is offline
