1/10 R/C F1's...Pics, Discussions, Whatever... >
Like Tree3128Likes
Old 09-22-2017 | 10:18 AM
  #13636
josecarlo1129's Avatar
TRG 117 chassis with electronics and wiring sans the Mercedes W07 polycarbonate body, in different angles.
Pardon the influx of photos. There is no specific TRG thread so nowhere to post and share stuff but here.
tommy911t, No9, LetGo and 2 others like this.
josecarlo1129 is offline
Old 09-22-2017 | 03:07 PM
  #13637
aracefan's Avatar
Share all you want, brother, share all you want.
Moar close-ups, please!
josecarlo1129 and Mr Brooksy like this.
aracefan is offline
Old 09-22-2017 | 03:47 PM
  #13638
mleemor60's Avatar
I would be interested in seeing a good close up of the front body mount and knowing if it is something particular to that chassis or could be used on other cars as well.
mleemor60 is offline
Old 09-22-2017 | 07:07 PM
  #13639
RCBuddha's Avatar
https://www.google.com/search?q=tech...qYuPbZNDvc9IM:
Does anyone have this part and if so, can you post a picture?
RCBuddha is offline
Old 09-26-2017 | 10:47 AM
  #13640
I need some idea of a starting gearing recommendation. It's an indoor carpet track, and i'm running a 25.5 motor. A FDR, or pinion for a 63 tooth spur would help too.
Nerobro is offline
Old 09-26-2017 | 10:59 AM
  #13641
MantisWorx's Avatar
3.0 is a good starting point
MantisWorx is offline
Old 09-26-2017 | 11:59 AM
  #13642
Thank you. I even have that pinion on hand.
Nerobro is offline
Old 09-26-2017 | 09:16 PM
  #13643
f1larry's Avatar
If you are going to be racing at Windy City, 3.0 is a good starting point.
f1larry is offline
Old 09-27-2017 | 07:32 PM
  #13644
tommy911t's Avatar
Been a few years since I raced F1. There used to be a few kits like 3 racing and speed passion that were extremely inexpensive yet still competitive. I'm trying to help friends get into F1 without breaking the bank. Assuming most folks have a spare shorty lipo, what would be your opinions on the least expensive new F1 kit and motor/esc package? Or, what would you do if you had to piece together 2 or 3 loaner cars?
tommy911t is offline
Old 09-27-2017 | 10:46 PM
  #13645
Default Impact of Spring rates
Hey all,
Was hoping to get a brief explanation of the effects on changing the spring rates on the side springs and front springs.
Generally, what role do they play in handling? Impact of going harder or softer?
mstrfahrenheit is offline
Old 09-28-2017 | 12:37 AM
  #13646
Mr Brooksy's Avatar
I'm really really happy with my serpent SF2W. Cheaper than the Roche or XRay, but not any less capable from what I can see. There is the new SF3 and they are still cheaper than the newer hyped models.
I have read many times though that is best to buy something that you can get local support for. But honestly with online parts so freely and quickly available I've yet to be stuck without something for more than a few days.
MantisWorx and tommy911t like this.
Mr Brooksy is offline
Old 09-28-2017 | 04:09 AM
  #13647
Originally Posted by mstrfahrenheit
Hey all,
Side springs,
They affect to general traction and initial steering. Going softer will increase rear grip and reduce initial steering. If your car is lazy, it is a quick change going to a harder one it will give you a bit more initial steering. The same if your car is too edgy you might find a help softening side springs. On carpet softening side springs help to solve grip roll.
Front spings, I have not played that much with them.
The softer, the more steering will provide, but also, it will make braking harder. For bumpy tracks you will need a softer one. A harder sping in the front will make the car react a bit quicker. A really soft spring can collide on high speed turns making the car behave weirdly.
At the moment I am using mostly Xray springs on my Exotek F1.
Side springs from 0.9 to 1.5. really it depends a lot of traction and surface, but I keep working with 0.9 and 1.2 most of the time. High grip carpet 0.6
On the front outdoors 3.0 or 3.5 and indoors 2.0 or 2.5.
Cheers
Javier
jimjav is offline
Old 09-28-2017 | 02:53 PM
  #13648
robk's Avatar
Strangely enough, this post appeared in the XRAY X1 forum, referencing advice from Xray team driver Jan Rathiesky
Originally Posted by cheapskate.brok
Managed to meet Jan and had a chat with him at the recent TITC held in Bangkok early this year. One advice that he gave was lighter tube damping for high traction tracks and heavier for low traction. The idea behind this was to allow the car react according to available grip, a slower transitioning of weight on low traction tracks does not break the grip threshold.
I'm personally running 30k in the side tubes, 1.2 springs and Tamiya soft at the front, meant for the F104/3. They cost USD2.50 with three ratings, 2 pairs each.
Tamiya F-1 Front Spring Set
Tamiya, F-1 Front Spring Sst ,(50509)
Generally, as traction comes up, you go to lighter springs. Lower traction, heavier, as grip allows.
In super high traction, lighter springs let the car roll within the suspension travel. Stiff springs will make the car act more like a door hinge and want to traction roll when the springs reach their limit of roll. In lower traction, stiffer springs keep the weight from transferring too much and break the tires traction, as referred to above.
All of this is subject to limits, but it's a general guide.
As always, make it easy and look at the setup helper from xray. Most of the info is universal.
http://site.petitrc.com/reglages/xra...6_SetupHelper/
robk is offline
Old 09-28-2017 | 09:48 PM
  #13649
RCBuddha's Avatar
Tempting....
PDR, aliceisadog and Mr Brooksy like this.
RCBuddha is offline
Old 09-28-2017 | 11:13 PM
  #13650
Mr Brooksy's Avatar
What rear wing is on that! Is that a new Tamiya release?
