Team Associated RC10B64 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree710Likes
Last edit by:
Print Wikipost
Old 09-19-2017 | 04:43 PM
  #2641
rgrg2's Avatar
Originally Posted by E-Mann
I run the longer shocks and tower with vrp valve pistons, chrome shafts and machined internals. It has really helped keep the back end stable on a very bumpy loose track. If your track is bumpy I would say it's worth it. For smooth Clay I wouldn't bother.
I run with the orings but wouldn't say it's necessary. I have never run without them to see how close it is to having the drive shaft pop out from the center outdrives.
Originally Posted by Krio
The O-rings help prevent the pins on the dogbones from hitting the G-clip and ejecting them. If you switched to snap rings, it doesn't matter.
Originally Posted by daedalus
I run with the long rear tower + shock body on indoor bumpy clay and it helped settle the rear of the car significantly. All of the "fast" local AE drivers run long rear towers at our track.
So even if it is a fairly smooth, clay track, the longer shocks and tower are still good to use? It doesn't necessarily have to be real bunny or a loose track?
Thanks for the replies!!
rgrg2 is offline
Old 09-20-2017 | 06:37 PM
  #2642
The longer shock bodies obviously hold more fluid, therefore work better for jumps and bumps. They can be used anywhere. The conditions you would run the shorter shock bodies and tower would be very smooth and high bite astro or carpet, as it keeps the center of gravity lower.
rgrg2 likes this.
Chris Brown is offline
Old 09-20-2017 | 06:56 PM
  #2643
rgrg2's Avatar
Default Shocks
Longer ones good for OCRC?
Thanks!
rgrg2 is offline
Old 09-20-2017 | 10:56 PM
  #2644
yes.
rgrg2 likes this.
Old 09-22-2017 | 05:39 AM
  #2645
LA-2-AL's Avatar
Originally Posted by LA-2-AL
If I stick with the class then yes, I'll probably upgrade the motor,, the 17.5 was what the guy threw in the deal to get me started
Thank for the info I was a little worried about that too, I was going to pick up a 28 to start, I'm going to pull it apart and confirm the 81 or 78 before I do anything,, I assumed it was a 81 because I thought that was the stock gear,, but I'm not 100% sure because I bought it assembled.
if the 17.5 isn't really workable,, well I know what to do.
tnx
So I confirmed it is a 81t spur,, was going to order a 28 pinion unless the recommendation is getting the 78t spur and a 30-31 pinion??
LA-2-AL is offline
Old 09-22-2017 | 02:57 PM
  #2646
Does anyone have the running weight of this buggy with all electronics, tires and battery? I have a TLR 22-4 1.0 and with everything (Ti screw kit) it comes in at 1771g. I heard the new Tekno EB410 comes in at 1742g ready to run but was wondering what this buggy comes in at. Thanks!
FPMX772 is offline
Old 09-22-2017 | 03:29 PM
  #2647
Mine is 1675 with thin pack
todb is offline
Old 09-22-2017 | 03:32 PM
  #2648
What other upgrades do you have in it?
FPMX772 is offline
Old 09-22-2017 | 03:35 PM
  #2649
Ti screws, turnbuckles, lightweight body.
todb is offline
Old 09-22-2017 | 06:31 PM
  #2650
Nice! Thats a lot lighter than the TLR wheeler. Might have to get a AE since we run a lot of 13.5 here
FPMX772 is offline
Old 09-22-2017 | 06:40 PM
  #2651
Yes it is pretty good. And not hard to drive either. The TLR is still pretty good car to drive in 13.5 even with the extra weight imo.
todb is offline
Old 09-23-2017 | 07:13 PM
  #2652
When your talking about long shocks, is it this kit? Part 91498 for the complete set?
tntpower is offline
Old 09-23-2017 | 08:29 PM
  #2653
jabroni racing's Avatar
Originally Posted by stonerrockMP
Hi, does anyone know how to solve the horrible and very embarrassing whining noise that comes from the gearbox? Ive rebuilt this thing so many times the threads in the plastic parts are now rubbish. Not keen on throwing more money this.
Love my B64 but the Noise makes me miss my whisper quiet 22-4 2.0, LoL..
windycityblues likes this.
jabroni racing is offline
Old 09-23-2017 | 09:19 PM
  #2654
That kit looks discontinued. The only difference you need is the 31mm body. The shock shaft and all other parts between the 27.5mm shock and 31mm are the same. So if you already have the rear shocks you only need asc91758 for kashima bodies or asc91482 for the standard bodies.
Old 09-26-2017 | 09:53 AM
  #2655
rgrg2's Avatar
Default Arm mount pills
Is there a pill chart for the B64D that has how the front an rear pulls affect the toe and anti squat? I know the B6 has the pill chart, but is it the same for the wheeler, and affect on the front?
rgrg2 is offline
